Question about De Dietrich Ovens
De Dietrich double oven FX4827E35 problem, Did pyrolitic clean.Top oven door will not open and display is saying "Er2". Help/guidance please
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 26, 2010
heatman101
  • 43501 Answers
SOURCE: I have a UMP 404 de dietrich oven user manual
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Jul 18, 2010
  • 80 Answers
SOURCE: de dietrich oven , panel shows er2
Tools- philips scredriver, Torx screwdriver
Disconnect from the mains. Open the oven door- use a screwdriver to lever the latch up if it's still locked. Unscrew the 2 screws that hold the oven in the carcass. Pull the oven out from the unit about 6" (you don't need to remove it). Undo the 2 torx screws on the top of the oven and push the top cover of the oven back to reveal the electrics. On the left hand side you'll see a black plate with a reddy brown actuator and a switch. Remove the black plate by taking out the 2 torx screws from the left hand side of the oven. Unclip the switch from the black plate and push it to one side (you don't need to disconnect the wires). Disconnect the reddy brown actuator wires (red on left, black on right although it doesn't actually matter). Remove the plate complete with actuator. Pull the front of the actuator up and slide out forwards, releasing the whole actuator. Don't lose the spring! The little piston at the front of the actuator should only be sticking out a few mm (about 3-4). If it's sticking out more, then it may be stuck. So...
Seperate the 2 halves of the actuator by twisting the bayonet. The actuator half should have it's piston fully retracted, leaving a little flange sticking out. If it's not fully retracted, the actuator is toast and needs renewing. If it is fully retracted, pull out the 2 black parts and the plunger from the part you twisted off the actuator and make sure they are free and not sticking (this is what was wrong with mine). Reassemble the actuator and clip back into the black plate with the spring behind it. Reconnect the power cables. Install the switch. Install the sub-assembly in the oven. Replace the top cover of the oven. Slide oven back into the unit carcass.
Done!
Thanks
Posted on Apr 02, 2012
Testimonial: "totally did what you told me to , word for word, and my oven is working once again , thanks!"
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
How do i unlock a de dietrich oven?
In order to unlock the oven you need to perform the following:
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
Jun 25, 2011 | De Dietrich Ovens
heatman101
Jul 17, 2010 | De Dietrich UMP404 Powerclean Stainless...
Fault 23 is displayed on the control panel after using teh self clean function on our miele double OVEN H398 BP2. IT IS NOT LISTED ON THE MANUAL WAHT DOES IT MEAN?
F23 means that the required pyrolitic temperature was not reached during the self-clean cycle. If the other half of the oven does not do this, then it could be a problem with a door lock switch or one of the overtemp sensors.
Dec 12, 2009 | Miele DG 4080 Stainless Steel Electric...
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
Thank you for contacting Fixya.com
Aug 07, 2009 | De Dietrich Ovens
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
Ovens Logo
37 people viewed this question
Top De Dietrich Ovens Experts
ashburton
richie46
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
