My cadet wall heater fan turns on but the heater elements don't. What could be wrong
2 Suggested Answers
SOURCE: Cadet wall heater
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Posted on Oct 20, 2008
Fan works but no heat
look to see if the safety fuse is open you can do that by using a continuity test on the heating element.
Feb 12, 2015 | Cadet EnergyPlus 1600 watt 120/240 Volt...
My cadet wall heater wont turn off
My cadet heater was doing this so I pulled it off of the wall and saw that the two wires coming from the thermostat portion had melted out of their insulation and were crossed. The heat is of some concern, but for now I just wrapped them in electrical tape to insulate them better against melting
Mar 11, 2012 | Cadet Manufacturing Built-In Wall Heater
FAN IS BLOWING BUT NO HEAT
hello,
this means that the heater of your cadet have been disconnect from it position or it has gone bad
please note this, that the heater is call element technically if you to get a replacement for it
what you have to do from here to fix up cadet is that unscrew your heart with the basic tools trace the maize i.e the wire down fan then trace the wire from the fan to the element it's always white in colour if it's properly connected from it position then you have to passive it if smiley borne meaning that it has gone bad then it will need replacement,
but if it is disconnected then you will have to do the fixing you self by peaking up the loss wire and fix it up back to the position
thank you and thanks for using fixya.
May 03, 2010 | Cadet Manufacturing 67507 Heater
Melted plastic on the heater element.
Safety overules your financial decision, get a new element.
Feb 11, 2010 | Cadet Manufacturing CADET SL Series Small...
My cadet c202 heater is running the fan is blowing cold air but no heat, is it the thermostat or heating elements or both???or ?????
I work in a motel and replace these heaters quite often, Cadet C202, a 240v 2000 watt wall heater. Most of the time when they blow cold air it's because the heating element is broken. First turn off the circuit breaker, then remove the heater from the wall. If you take out three screws, slide the top cover off, bend the two little tabs and take out the heating element, you can examine it and usually you will find a place where it is broken, it's like a big spring. Replacement elements can be ordered from online stores such as reliableparts.com Be very careful, 240 VAC is very dangerous! <!-- from fixya rte -->
Dec 31, 2009 | Cadet Manufacturing 67507 Heater
There was an electrical smell when the heat was on
Could be ,to be certain take it out the wall and check
Mar 07, 2018 | Cadet Manufacturing 67508 Coil / Ribbon...
No heat
The element above the fan has brobably gone bad. you can take the grill off of the wall and inspect the coils for breaks with a flashlight. if you do see a break in the coils then the heater is toast.
Oct 05, 2008 | Cadet Manufacturing 67508 Coil / Ribbon...
Cadet wall heater
Sep 11, 2008 | Heating & Cooling
Cadet heater quite working
that round metal thing is called a klixon overload. look on the side of it and an amperage range should be there. replace the unit and the element should work unless the element itself is blown. check for continuity across the element with your meter with the wires disconnected.
Nov 03, 2007 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
