Error code e62?
Mfd70-d12201 washer/dryer stoped, door blocked, nothing work and on display show eror code E62
5 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: ewf1087 showing E62 and door locked
    Check for short circuit across heater relay(s) (RL5, RL6, RL7) or L1 applied to heater relay output(s) (J5-2, J7-1, J7-3) with cycle stopped. Check for open circuit between L1 and heater relay connection(s) (J5-1, J5-3, J7-2). If no wiring problems are found, replace the Main Control Board.
    Posted on Sep 05, 2012
    SOURCE: i hv an error code of e62 on media washing machine
    what's the model number?
    Posted on Jan 04, 2015
    Ngoro
    • 1144 Answers
    SOURCE: Zanussi washing machine showing Error Code E62, why ?
    Zanussi Washing Machine Error or Fault Codes
    Washing Machine Repair with Active Appliance Repairs
    Posted on Feb 15, 2015
    Has a e62 error
    Frigidaire Washer Error Code E62 - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
    May 1, 2015
    Frigidaire Affinity Front Load Washer Won't Start ...
    1 post
    Dec 4, 2013
    Frigidaire washer E6E error
    Jul 31, 2012
    frigidaire affinity E62 error code
    Oct 30, 2010
    More results from forum.appliancepartspros.com
    Oct 19, 2015 | Washing Machines
    Zanussi zde47100w what else can a e62 error be
    E62, is a faulty heater unit, faulty wiring or faulty main control board. You have already changed the heater unit so check all wiring. If OK, then you will probably be looking at a new control board.
    Apr 08, 2015 | Washing Machines
    I have a Frigidaire Affinity front load washer ATF6000ES. The lights on the control board go on and off on their own and it beeps at the same time. I've tried resetting it but have the same result. When I...
    Thank you for your inquiry, Steve Lesko!
    I understand that your Frigidaire washer is displaying an error code of "E62" and the lights on your panel go on and off with a beeping sound. I do not show "E62" as a valid code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your range. You can do that by disconnecting the power from it for roughly ten minutes. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or other error codes? With this information I can better address the issue at hand. In the meantime, I suggest resetting your washer. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E62". I look forward to assisting you. -Matt
    Jan 30, 2015 | Frigidaire Washing Machines
    E62
    Good Morning John, thank you for your post!
    I see that your Frigidaire washer is continuously beeping and displaying error code E62. However, I show that the correct error code is EB2. Typically, EB2 indicates that the incoming line voltage is above 130VAC. Please verify that the power supply is correct. You may also disconnect the power to your washer for up to ten minutes by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, it would be advisable to contact a professional the since the main control board is possibly faulty.
    May 23, 2014 | Frigidaire ATF6000ES Front Load Washer
    E62 code on display
    E62 - Power relay to heater unit faulty
    Could be:
    • Heater unit faulty.
    • Wiring faulty.
    • Electronic board faulty.
    At this fault appliance forced cooling cycle.
    Dado
    Mar 11, 2014 | AEG T57800 Electric Dryer
    Washer turning on and off with beeps showes e62 error
    Hello coollove60, thank you for your post!
    I understand your washer shows error E62. However, it appears the correct error code is EB2. Typically, it indicates that the incoming line voltage is above 130VAC. Verify power supply is correct. If so, it would be advisable to contact a professional the since the main control board is possibly faulty.
    Jan 25, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Error code
    E62 = System Contact Error. System contact error is just a fancy way of saying the washer has a loose connection. This connection can be anywhere on the machine, so check all connection plugs by unplugging and re-connecting all connections one at a time. If you don't find a loose connection, replace the control panel.
    Read more: http://www.appliancepartspros.com/ge-main-pwr-board-we4m488-ap4980176.html#ixzz2qOlJ8wDy
    Jan 13, 2014 | Dryers
    Hi I have an Electrolux dryer which has started showing the error message e60, when i hold the start button and the one next to ity I get error e62 showing can you help?
    the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
    the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
    May 12, 2011 | Dryers
    Washing Machines Logo
    57 people viewed this question
    Top Washing Machines Experts
