Question about Coffee Makers & Espresso Machines
Two things. First, leakage from under the coffee maker, and second, how to increase temp on the single serve side
  • 625 Answers
SOURCE: Coffee maker side will not work.
check inside for broken or burnt connectors going to the heater element. these are normally slide in spade connectors.
Posted on Sep 10, 2007
  • 625 Answers
SOURCE: how to clean??
you'll need a phillips screwdriver and a small crescent wrench. start by unplugging the unit. unscrew the sprayhead. remove the small hexnut from the sprayhead tube. remove the two screws from the top cover and lift up the cover. if there is a warmer element on it, remove and mark the two wires to the element. use the back end of the crescent wrench and unscrew the brass nut in the reservoir. save the fiber gasket from under the tray. the pot holds two complete potfuls of water so be careful. mark all the wires and where they go and remove them one at a time from the top of the canister. remove all the screws or nuts that hold the top to the canister and remove the top. the thermostat bulb goes into one of the plastic bushings along with rubber packing washers in the top. unscrew the plastic bushing, the packings and the thermostat bulb. pour out all the water from the canister. there's a dip tube that goes to the bottom and is fastened to the water inlet pipe on the top part. this may have some scale build up on it. scrape off this deposit. in the bottom of the canister you will find a mineral scale which must be removed. a small sharp chisel without the use of a hammer can be used to remove this scale. while you have the machine apart, use the long steel spring to clean out the water tube that goes to the sprayhead.
Posted on Jun 05, 2008
  • 8596 Answers
SOURCE: Cuisinart DCC 1150: coffee is not hot enough
Using the 1-4 cup setting will help, but that model does not have an actual heating element in the plate - definitely not the right model for someone who likes very hot coffee.
Posted on Jan 15, 2009
  • 3085 Answers
SOURCE: lost instructions coffee per water ratio (30 cups)
1 1/2 cups of coffee grounds for 30 cups of water
Posted on Mar 07, 2010
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
I have a cup o matic and it has recently started leaking from the main unit...???? Can I fix it?
you can if you can find where the leak is, and as long as it is just a worn o-ring and not a crack. You could contact Cuisinart for service? There are some articles on your particular problem in the main link at the bottom.
Pt 1: How To Use: Cuisinart SS-1 Cup-O-Matic Coffee Maker - YouTube
? 10:04
Oct 18, 2007 - Uploaded by Jay Brewer
Learn how to use coffee pods and ground coffee with the Cuisinart SS-1 Cup-O-Matic Coffee Maker.
SS-1 - Coffee Makers - Discontinued - Regular or bold, large or small - your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffeemaker, it's easy to brew your cup ...
[PDF]Cup-O-Matic™ Coffeemaker SS-1 - Cuisinart Cup-O-Matic™ Coffeemaker. SS-1. For your safety and continued enjoyment of this product, always read the instruction book carefully before using. Customer reviews: Cuisinart SS-1 Cup-O-Matic Single ... Find helpful customer reviews and review ratings for Cuisinart SS-1 Cup-O-Matic Single Serve Coffeemaker, Black and Brushed Chrome at
Cuisinart® Cup-O-Matic™ Single Serve Coffee Maker - Bed Bath ... Regular or bold, large or small, your ideal cup should never be compromised. Now with the Cuisinart® Cup-O-Matic™ Coffee Maker, it's easy to brew your cup ...
Cuisinart Cup-O-Matic Single Serve Coffeemaker Review Rating: 2 - ‎1 review
Unlike coffeemakers that only make a cup at a time, this model can be used with your favorite ground coffee as well as from coffee pods.
Single Serve Coffee Forums
cup matic leaking water Google Search
Sep 03, 2017 | Coffee Makers & Espresso Machines
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ..., Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Why am i getting an error when I try to brew on the single serve side of my Hamilton Beach flexbrew?
Check your water level if there is to much water you will get an error message. Try removing some water and try single serve again.
May 02, 2015 | Hamilton Beach Coffee Makers & Espresso...
Descale T20 Bosch Tassimo
you need to use the cleaner disk (tucked into the back of the machine) and run through some of the cleaner solution. Then run though just water. Don't forget to store the cleaner disk back in the machine.
Sep 09, 2014 | Bosch Tassimo T20 Single Serve Brewer,...
Why won't my coffee single serve brew after cleaning?
You could try what this guy did with his
Aug 07, 2014 | Mr. Coffee Coffee Makers & Espresso...
Removable filter basket for black and decker cofee maker
Removable Filter Baskets for BLACK & DECKER Coffee Makers at:
Nov 04, 2009 | Black & Decker Black&Decker Home Cafe...
Oily film
ok descale your coffee pot ( machine) with vinegar.
If it still does it it will be your coffee or the temp of the brewer is too low.
I am a coffee junk and have had this problem. If your water is too cold it sometimes happens but coffee brands do this too. Some brands roast thei coffee too long and that releases the coffees' natural oils.
No problem if the taste is good
Apr 19, 2008 | Black & Decker Black&Decker Home Cafe...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
