Question about Haier Freezers
Hello! i have a Haier upright freezer and it keeps on beeping, could you please tell me why?
5 Suggested Answers
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
  • 4793 Answers
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Posted on Feb 11, 2010
  • 1524 Answers
SOURCE: true upright freezer. coil fan not running.
Let it run. Coil temperature has to be low enough for the fan delay switch to close.
Posted on Jul 14, 2010
  • 112 Answers
SOURCE: Hello I have a frigidare upright freezer i want
You can't....most freezers have set position so air can rotate evenly for a reason.
Posted on Jul 20, 2010
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
The alarm keep beeping and when I turn it to off (the reser alarm) the freezer will not keep food frozen. Please Help!
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Things will be good
Aug 09, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Beeping coming from freezer
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Feb 05, 2010 | Freezers
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
May 24, 2009 | Haier 9.1 cu. ft. / 258 liter Upright...
New freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Upright freezer
I went on a call for a problem like you explained. I looked everywhere and found that a battery in a smoke detector was low and warning that it needed replacing. No insult, but the customer and I were both were a little supprised. Now I have not found a fridge beep yet, so if you have already found the answer please let me know. So we can pass the answer on to others that have had the problem you listed. I realize our response time is late, I just saw it today. Please tell me what you found, Thanks, JT
Aug 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
93 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
