Question about Hardware & Accessories
HOW DO i OVERRIDE THE TIMER OF MY diplomat ADP4550 double oven. The timer is broken completely.
The timer appeared to blow when there was a power cut, the buttons do not press any more and led just flashes 00:00 all the time.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Get a new one. the power surge burned it out.
Posted on Mar 09, 2017
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
Forno sy36x oven.. following powercut, timer wont set, therefore oven wont come on. digits constantly flashing
after a power cut, the clock display will-automatically reset to 0:00 and begin to blink.
starting buttons left to rigth Press the
2nd and 3rd buttons simultaneously, release,
and then set the exact time (within 4 seconds) using
the +buttons.
advances the hours.
The button
- decreases the hours.
The time can also be changed in a second ways
1.Repeat all of the steps above.
2.Press the 4th
button, release, and then use the +and -
buttons to update the time.
Sep 23, 2014 | Ovens
Intermatic ej500 fuse
Why did fuse blow?
Is timer under-rated for load on line?
Do wire size and breaker size match?
EJ500 is rated incandescent-only with maximum 500 watts, with temp range from 32 to 104 F, maximum distance 100' from load, and timer has 1 year warranty against defects.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Color-codewire.html
Try resetting timer.
This will delete both programs and current time settings.
Hold down on-off button, and press and release reset button.
Keep holding on-off button until display changes, and 12:00 is flashing.
If timer will not reset, try changing battery.
Simple power outages, and blown fuses can cause power surge that will knock out timers. This is a common problem, and resetting timer can usually solve problem.
Timers like outdoor power pack, and analog plug-in timers do not have reset button and can easily fail after ordinary power outage.
Jul 29, 2012 | Intermatic EJ500C - Indoor Digital Wall...
Setting clock
Hello
To set clock:
1. Press "Timer/clock button". The hour digit begins to flash.
2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.
3. Press SET button. The minute digits begins to flash.
4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.
5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer.
If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Jan 21, 2012 | JVC MX-D402T Shelf System
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
So my intermetic time is broken, the gears dont turn, and the on/ off override isnt working. I need my pool heater, what do i do?
Sounds like you lost power to the timer. Look in your electric panel for a tripped breaker. Turn it OFF then back ON.
Aug 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
I have a diplomat double oven no instruction or model no the bottom oven will not turn on and i can not get timer to cancel also an a is flashing on top left hand side of clock can you help ?
Sounds like the flashing 'a' means the timer is in automatic mode. I trust that when you turn the bottom oven to on the oven indicator light does not come on. Turn the bottom oven to ON. Then
have a fiddle with the timer. You have to get it to manuel mode. When it goes on to manuel mode the oven indicator light will come on and the oven will then work.
Feb 05, 2011 | Ovens
Hardware & Accessories Logo
335 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
