Question about DeLonghi Ovens
My delonghi oven is making a ticking noise and with all the switches turned off it's is still heating and rather hot. Won't turn off and cool down
    Master:
  • 610 Answers
Sounds like an improperly grounded element in the circuit... If an element or wire makes contact with the metal frame and welds itself in place, the electrical current can BYPASS the control and heat uncontrolled- throw the circuit breaker to interrupt the power.
A thorough inspection must be made of the elements and wiring.
Help Me Find My Model Number
Posted on Dec 16, 2016
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
  • 1462 Answers
SOURCE: oven heats up then switches off
there is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
Posted on May 20, 2007
SOURCE: kenmore oven
I noticed your question and I just experienced the same problem. Curious if you found the solution or not, since no one has posted one?
Posted on Aug 09, 2007
barkencoa
  • 3463 Answers
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Posted on Jan 02, 2009
  • 142 Answers
SOURCE: Oven blown up??? Is it a simple fuse or is it a big job???
sound like fuction switch has blown apart quite common and the noise is prob coming from cooling fan and not the main one inside.
Posted on Sep 14, 2009
Fan oven over heating
I would contact the manufacturer .there could be a recall on it if you make them aware of the problem .
Dec 12, 2015 | Ovens
How do you stop the clock ticking?
You could turn off the oven at the isolator switch. Turn it on again when you need to use it.
The time really only needs to be accurate when you make use of features like a delayed start when baking bread, or to stop baking meringues and let them cool slowly in the oven.
Just be sure to check that the Auto/Manual switch is set to manual unless you're doing the above type of baking.
Feb 28, 2014 | Candy Ovens
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Sep 14, 2009 | DeLonghi Ovens
Timer is making ticking noise cant turn it off.
My same oven makes a ticking sound when you tell it to start pre-heating the oven. The oven continues to make this ticking sound until you stop the oven and it completely cools down. This ticking sounds to be coming from the oven control panel. I have no solution, but I'm glad I wasn't the only one who had a problem with this ticking sound!
Jul 15, 2009 | Ovens
Baxter ov300e electric oven
When you say the oven doesn't want to turn on are you referring to the control board wont turn on? Or are you saying that the oven wont heat when it gets too hot?
Oct 19, 2008 | Baxter OV300E Stainless Steel Electric...
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Blower remains on when oven is turned off
yes it is normal i have one and it has been doing that sine i brought it i took it a part and there is nout wrong with it so yer its fine
Jan 05, 2008 | DeLonghi DEBIG24 Gas Single Oven
Ovens Logo
Top DeLonghi Ovens Experts
ashburton
Jason Harris
Jason Harris
Naftali Haskell
Level 1 Expert
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
