Question about Lenovo Computers & Internet
My Lenovo laptop won't connect to the wifi. TVs are connected to the wifi so I know it's not a problem with that & I tried to connect the laptop to my phones hotspot but still nothing. Someone helpppp
    Problem Solver:
  • 13 Answers
Sometimes it is incompatible devices, while standard wi-fi everything should work. Try updating the driver on wi-fi card, change the channel, and encryption type.
Posted on Dec 12, 2016
SOURCE: Lenovo 3000 Y410 Wifi Problem
If this is the case, reboot the machine and then see if the wireless works.
Posted on Sep 25, 2008
SOURCE: my wifi in my laptop diaspeared
I posted that I was having the same problem. At this point I'm not sure that it was in fact the same problem but my issue was solved by removing and then re-seating the internal wireless card. It looked pretty secure with two screw holding it down but, that seems to have been the problem with mine.
Posted on Feb 28, 2009
  • 38 Answers
SOURCE: IBM Lenovo T60 connection to Samsumg 50'' TV using CGA cable
Try just pressing "Fn" and "F7" keys until the output switches to your TV.
Posted on Mar 24, 2009
tbreeze47
  • 3083 Answers
SOURCE: Lenovo thinkpad keeps dropping internet
This sounds like bad wiring from the internet side, or noise on the line, which would drop the connection, but not enough to indicate it. Get the line checked to make sure it's a strong, clean signal. Good luck, hope this helps.
Posted on May 20, 2010
  • 256 Answers
SOURCE: problem with the wifi lenovo G450
Be sure your wireless switch is on. Then check your device manager. If it has yellow mark under network adapters, then you need to download driver for that. Click here to download driver. If that won't still work, try uninstalling Lenovo Readycomm from the list of your programs in Control panel. If that still doesn't work, contact your service provider to configure the wireless settings of your pc and router.
Posted on May 25, 2010
Lenovo Laptop won't connect to internet?
Might be your wifi adapter has failed try installing external wifi us \b card
Dec 02, 2015 | Lenovo Computers & Internet
Can't get setup to Internet from Lenovo ideapad
are you running windows 8 if so take your mouse to the righthand side of screen there will appear a side tollbar at the bottom there is a wheel tipe thing /settings press this in there is your wifi settings /sounds /shut down click on wifi this then should be the the networks you can connect to using you wifi code
Dec 26, 2012 | Lenovo IdeaPad Z380 Laptop Computer -...
Can't get internet connection all of a sudden on lenovo U330 laptop. Need setting information I guess. Wireless icon says I am connected, but when I try to log on to a website, i get a message saying...
what is the operating system are you using and for the internet connection go to the run from start menu and type cmd then enter , in the black screen type ipconfig and check the ip address and see if it is 169.254.x.x if it is in this range then you dont have a internet connection and if not and if you are getting anything else then type "ping www.google.com" and see if you get 4 packets send and recieved and 0 lost you have a browser issue and by the way go to network connections and see how many computer symbols you see and then enable all or connect it and then try to connect if you are able to if yes then ok and if no plz tell me whats happening.
do reply back with the above asked information and tell me if it was helpful by voting
Nov 04, 2010 | Lenovo IdeaPad U330 Laptop Computer -...
I dont know to use wifi in LENOVO 3000 Y410
Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 1 Purchase a wireless router that fits your needs and price range.
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    Problem with the wifi lenovo G450
    Go to control pannel system device manager check that the devise driver is installed if not go here
    http://laptop-driver-download.blogspot.com/2009/09/download-lenovo-g450-windows-xp-drivers.html
    They have all of the nessary drivers
    May 25, 2010 | Lenovo 3000 Y410 Notebook
    Wifi connection drops after it connects to the wifi
    you can make sure your new laptop is on only the g band that should help, cos its trying to go on the n band which is causing it to drop.
    Oct 10, 2009 | Linksys Wireless-G Broadband Router
    Won't connect to WiFi home network, keeps coming up with ünable to connect". My other laptop connects automatically
    Go to device manager, network adapters, select your wifi adapter, right click then uninstall it. If you're with Vista, do not delete the drivers. Then when its gone, select action on device manager and scan for hardware changes. It will re install the wifi adapter back. Now try to reconnect back to your router, put in your security key and once connected, save it. When you boot it up again it should connect back automatically again.
    Hope this helps.
    Oct 02, 2009 | Lenovo IdeaPad S10e Netbook
    Computers & Internet Logo
    Top Lenovo Computers & Internet Experts
    Michael Vincent Cruz
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
