What to do when a washing machine displays the e6 error code
pierre1811
  • 144 Answers
SOURCE: E6 error code displayed on Kenwood kdw243a dishwasher
The reset sequence used is:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Posted on Jan 19, 2009
SOURCE: ERROR CODE F07 ON DISPLAY
Solved by heater replacement, cca 7eur in Belgrade.
Posted on Apr 06, 2009
kapishtech
  • 2272 Answers
SOURCE: error code f h
The FH code in the owners manual talks of a water supply.The F/H code means the unit isn't detecting water fill at the flowmeter. The flow-meter sits just in front of inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems. check figure for flow-meter location. c3a1d6e.jpg
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Sep 16, 2010
  • 3 Answers
SOURCE: I have a samsung sensor
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
  • 3 Answers
SOURCE: Samsung P801DWNXRC Frontload washer displays E6 error code
Daewoo front load error code E6
daewoo washing machine error code e6
Feb 11, 2018 | Daewoo Washing Machines
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
E6 error code on fisher & pykel single door dishwasher
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG Control Panel Overview
www.lg.com > ... > Repair > Locate Repair Provider
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
Nov 19, 2015 | Fisher and Paykel Dishwashers
E6 error will not wa what is an e6 error Lg top loader
Check out this website as it may help you.
The Fault has something to do the drive system of the washer. Different model however should be the same. LG WT4870CW error code E6 The Laundry Appliance Repair Forum
Nov 15, 2015 | LG WT5101H Top Load Washer
E6 error I need help
Good Afternoon Ismael, I am happy to assist you. However, could the error code possibly be missing characters? According from my research Frigidaire does not have an E6 error code. Meanwhile, let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the washer on. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display E6? With this information I can better address the issue at hand. Thank you and I look forward to your response.
Aug 15, 2013 | Electrolux Washing Machines
Brother sewing machine screen displays E6
E6 is an error code. You didn't state the model number, but if you look in your instruction manual, it will list the error codes. If you don't have a manual, go to Brother.com and you can get the answer.
Oct 01, 2009 | Brother Sewing Machines
Apr 28, 2009 | Samsung WF337AA Front Load Washer
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
