Question about Cell Phones
So im having trouble moving internal files from my verizon elipsis8 tanlet to an sd card i got from the store why is it so damn difficult lol please help
  • 13 Answers
SOURCE: Adding SD card to my ILO
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer? If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
Posted on Aug 28, 2007
  • 49 Answers
SOURCE: external memory - sd card recognition on pc??
if it doesn't even appear on windows explorer either the sd card, usb link or iriver is defective. if all else fails try getting a memory card reader. this allows you to store files on the card through the computer and still be able to insert the card as external storage on the iriver x20. the only trouble with that is that its hard to get the card in and out of the iriver
Posted on Nov 06, 2008
SOURCE: EnV2 does not recognize MP3 files on micro SD card
This was tricky, but I was able to get MP3 files recognized on my daugter's phone.
First, the MicroSD card needs to be formatted by the phone. The phone requres a special directory structure to be created. You may be able to do this manually, but I did it by letting the phone initialize the card. To do this, insert the MicroSD card. Make sure you push it all the way in.
Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 3 Card Memory. The phone should recognize the card and initialize it by creating the special directories for My Music, My Videos, My Sounds, etc.
Then put the card into your PC and copy your MP3 files to the My Music directory on the card. I could not get the phone to recognize sub folders, so make sure you copy everything directly to the My Music directory and not the one under it.
Now the card is ready, you have to tell the phone to use your card memory and not its internal memory for these items. Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 1 Save Options. Pick Pictures, Video, and Sounds and set the phone to use Card memory for each.
Now you can import the music into the music player on the phone. Go to menu 5 Media Center. Menu 1 Music & tones. Menu 4 My Music. The music player should then Import yhour music into the player and it should now be playable.
(I think these accurately reflect what I did)
You can also go to 9 Settings, 9 Memory, 3 Card Memory, 4 My Music to view your music.
Posted on Feb 07, 2009
  • 20 Answers
SOURCE: SD card can not be accessed on Sanyo NVM-4370
Did you hear a beep when SD card is inserted? Did you also try to hard reset the unit using the On/Off switch located at the bottom of the unit? Try with another SD card and see if the SD option is selectabe. If all have tried I suggest you to exchange for another unit. HTH.
Posted on Mar 05, 2009
  • 3289 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
How to move files to sd card
If you merely want to move photos, there is a pretty good guide at https://www.google.com/amp/s/m.wikihow.com/Move-Pictures-from-Android-to-SD-Card%3famp=1
If you merely want to change where your camera stores photos, where your browser stores downloaded items, where your radio app stores recordings, etc., you change that in your phone and/or app settings.
If you want to move more than that (such as moving videos you have downloaded from the web, pdf files you have downloaded, etc.) there are a variety of apps that will do the trick.
Some Android phones, such as the LG V20, come with a File Manager app already installed that you can use. Simply go to your list of apps and look for File Manager, and you can use that to accomplish the task. If your phone doesn't have a file mgmt app installed, there are several in the Play Store you can download for free. A popular one, and the one that I use since it can also manage your cloud storage, is ES File Explorer.
Once you have that installed, you can then navigate through your files and move what you want to your sd card.
For ES File Explorer, it has a feature rhat gives you quick access to files that it can readily categorize, making the moving of files pretty easy since you dont have to hunt them down on your phone. For some file types, though, you will need to dig into the folders yourself and find the files you want to move.
The steps to move files from your browser download folder would be:
1) when you first open the app you will see two boxes at the top. The one on left is Internal Storage. The one on the right is SD Card. Tap Internal Storage.
2) you will now see lots of folders. To browse the files in your Download folder, tap it.
3) to begin selecting files that you want to move, long press the first one you want to select. The mode will change to Select Mode and you can then Select All (button at top of screen), select additional files by tapping them, or tap a second one that's a distance away from the first one and then tap Select Interval (at top of screen) to select everything between the two you already selected (plus the first two you selected).
4) now that you have items selected that you want to move, tap Cut or Copy at the bottom of the screen (depending on if you want to keep the original), tap the tiny picture of a house in upper left of screen, select SD Card, navigate to where on the sd card you want the files (root directory of card, an existing folder, or create a new folder) and then tap Paste (bottom of screen).
If tou need to move files from another folder, it's kist as straightforward. The hardest part is finding what's stored where. For example, photos you have taken with your phone are normally stored in a folder named DCIM.
Use this tool with caution. Deleting the wrong file can result in apps no longer functioning correctly.
Hope that helps.
Oct 17, 2017 | Cell Phones
Can you help me solve this problem
Hook the phone up to a laptop or PC and download the files to the card that way.
Jan 31, 2017 | LG Cell Phones
Tablet claims to be out of memory but uninstalling apps doesn't free up any space. Even with 32GB SD card is says not enough room for new apps.
Memory in this case doesn't refer to the memory in your SD card, but in the phone or tablet itself. Biggest culprit is photos and music.
Uninstalling apps should free up space. Reboot phone after removing items to record the true memory available.
Sep 22, 2015 | Samsung Galaxy Tab 4G 10-in 32GB WhiteWith...
Im having problems with storage, its a nokia lumia 530 and says 3.04GB used the phone system is saying its using 2.68GB I have minimal apps, photos and no music yet I am almost out even after a reset
First, tell the phone to store new files and apps on the SD card.
On the start screen, swipe left, and tap Storage Sense.
Tap SD card for each file type.
Next, move existing apps to the memory card
Tap phone -> apps+ā€ˇgames -> bullet list icon
Select which apps to move.
Tap Move to SD.
You can later choose to move the most-used apps back to your phone from the memory card if running them from the card proves to be too slow.
Mar 06, 2015 | Nokia Cell Phones
Photos on verizon tablet were not stored on sd card, how do I get them on sd card
According to Verizon support:
"From the Device to a Removable SD Card This feature is not available on the Verizon Ellipsis 7 Tablet"
However, you can transfer photos from the tablet to a computer; and then you can transfer them to a removable SD card if you have an external USB SD card port reader or one that's PC integrated.
According to Verizon customer support:
From the Device to a Computer
  1. Connect the device to a computer using the supplied USB cable.
    1. If necessary, select and hold the status bar (at the top) then drag to the bottom.
    2. Select Connected as a camera / an installer.
    3. Select Media device (MTP).
  2. Launch Windows Explorer.
    linote.gif Using the computer keyboard, press Windows+E ( windows_key_logo.jpg+E) keys.
    linote.gif Alternatively, right-click Start then click Open Windows Explore.
  3. Using Windows Explorer, navigate: QMV7A.
    linote.gif If you have a microSD card, you may transfer files to that location by navigating: QMV7A > SD Card.
  4. Utilize the computer to copy video/picture files from the following folders to the preferred folder(s) on the computer:
    • DCIM/Camera
  5. Disconnect the USB cable from the computer.
Feb 28, 2015 | Verizon Ellipsis 7 Tablet for Wireless
There is no SD card in my phone....But can that be the problem
You only need SD card for storing extra data or for external storage. If your phone's internal memory has good capacity, you do not need an SD card for storing extra data.
However SD cards can be used for storing your important files externally. So if your phone doesn't support SD card, please keep a backup of your files elsewhere.
Dec 14, 2014 | Cell Phones
I have an android LG phone kit kat version, i have files on my sd card and even internal storage that when i click on then to open it says can not find a app that can open file
Please read this site. Just to make clear what you can do with internal memory, SD cards and so on in any Android device.
Be aware the SD card is only an external device to keep your files close to the device. You can't open them and you can't run any app from it.
To open files in the internal memory, toy need to have enough free internal memory to let the app that wants to open the file can run, and some extra space. If the memory is full you need to clear memory, by moving apps or data to the SD card.
How to transfer files and apps from Android phone Android tablet to SD...
Sep 18, 2014 | Cell Phones
Camera screen said SD card is locked when I installed an SD card
The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Need to reset!!!!
It might be a bit easier to have your friend delete it from their phone, just a suggestion. You can go to a verizon store lie like hell & tell them you bought it at another verizon store. If your lucky enough they'll be able to reset the H350 with their eguiepment.
Jan 26, 2008 | Motorola Mobility H350 Wireless Headset
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
