Question about Watches
How to stop numbers blinking and start Telstar watch working?
How to set alarm on oots MAI TAI RY2142 Watch for Women?
Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now. Now press and release the start/stop button (top right) and the minutes will flash, again for hours. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. To turn the alarm and/or the hourly chime on or off, hold in the adjust button (top left) and press the start/stop (top right). Each time you press the start/stop (top right) the CH or AL or both symbols. When the symbol is showing, that function is on.
Jun 02, 2014 | ROOTS MAI TAI Ry2142BLK Watch
DOESN'T WORK
If your watch is battery powered, it may be time to replace the battery
Jul 28, 2013 | Citizen Blue Angels Skyhawk Watch
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
Mar 08, 2011 | Caravell Bulova Caravelle watch
I have the timex 1440 wr50m radio control watch. I changed the time zone when I went on a trip and now I can't set it back to where it was. The manuals online are for newer watches, I guess, they have 6...
Good day Sir, This model (WR50M) has four buttons, from left to right, top to bottom: 1) Set; 2) Start/Stop; 3) Mode; and 4) Indiglo.
To set or change the time:
1.Press and hold Set and Start/Stop simultaneously; the seconds will start to blink
2.Release both buttons
Use Mode button to toggle through to Hours, Minutes, etc.
3.When desired number (such as Hours/Minutes) starts to blink, use Start/Stop button to change number
4.When done, hit Set
have a nice day.
Oct 15, 2009 | Timex 1440 Nylon watch
I need to adjust Timex 1440 sports watch. could you help me please. I have top left as mode, top right start/stop,bottom left indiglo and bottom right is set. Thank you jyo
Go to the time mode,hold down the set button, it may take a couple of seconds and it will start blinking , then go to your mode button to move from seconds to hour to min etc.etc,etc. It probibly is your start/stop button for chaning the numbers. If that dosn't work, hold down the mode button on the time mode for a few seconds, and go from there.
Jun 29, 2008 | Timex Watches
Cant set time
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish
Apr 01, 2008 | Timex 1440 Nylon watch
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Mar 30, 2008 | Timex 1440 Nylon watch
Setting watch
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
Mar 25, 2008 | Timex 1440 Nylon watch
Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
Mar 22, 2008 | Watches
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
Watches Logo
14 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
