Question about Car Audio & Video
What is the orange wire for on a hikvision ds2cd2012-I camera?
Cable for hikvision camera DS-2CE56D5T is cut. I m open camera and find 5 wires: white,black,red,green, yellow and blue. Which wires is power, signal...
four power wires, used mainly in CCTV installations. The cable may power distant cameras (each two wires can be connected in parallel), or be used for cameras equipped with audio module (one pair can power the camera, second - transmit audio).
Aug 03, 2016 | Miscellaneous
I have a Q-SEE security camera, that received water damage from a rain storm. The ethernet connector had to be removed and I am interested in hardwiring the camera to my CAT5e cable. The QCN8004B camera...
I had the same problem and had to rewire the ethernet jack on my Q-See camera QCN7001B.
The wiring I found was different than on the Q-See website.
Pin 1 is brown
Pin 2 is purple
Pin 3 is orange
Pin 4 is yellow
Pin 5 is blank
Pin 6 is blue
Pin 7 is blank
Pin 8 is grey
Apr 06, 2014 | Security Labs Home Security
Hikvision ddns
I rarely rely on the DVR/NVR manufacturer's DDNS services.I prefer to use companies that specialize in this like They are more reliable than anything. We offer an updater service for $39.95/year that is guaranteed reliable 365 days a year.
Oct 31, 2013 | Computers & Internet
GeoVision NVR Software for 3rd Party IP Cameras
Not exactly sure of the question but Geovision does allow for many 3rd party IP cameras to be connected. Check the Geovision website for a full compatibility list. I have personally worked with Hikvision and Vivotek with no issues. You will need to purchase and install a dongle. The dongle comes with software that you will need to install before using the USB dongle. The dongles come in 1, 2, 4, 8 & 16 camera capabilities. There is usually no cost difference to buy two 2 camera dongles or one 4 channel dongle. So get whatever you need. Just be aware that is will look odd having 4 USB sticks protruding from your NVR. There are also some internal dongle options that connect directly to the motherboard.
Oct 10, 2013 | Geovision 32 Channel NVR Software License...
TP-LINK TL-MR3020 need DUC or not i connect only hikvision dvr
Remotely would imply a different building or location. What exactly are you trying to accomplish? Do you mean hook it up in one room and record and watch shows in another? Or over the internet? Give more info.
Feb 02, 2013 | TP-LINK TL-MR3420 Wireless Router
Trying to connect Apexis camera to internet
Hello you can download a manual here if you don`t have it:
Here is a orange live box fault finder:
The IP camera must probably have a static ip adress in order to work.
When the ip adress is dynamic the software can`t find the camera everytime you turn on your pc.
You can buy a switch to connect between your pc and the modem
and connect the camera to the switch.
But you have to install the software again.
Good luck
Dec 14, 2012 | Apexis APM-J802-WS Wireless Wired Pan Tilt...
Installed reverse camera to Eonon E1025 unit. Power for the camera was taken from the reverse lights (positive and negative). Video wire from camera was taken back to the E1025 unit. I expected the orange...
i had the same problem with my talon today, all you need to do is get another wire , connect one end to the 12v(red)backup tail light wire and connect the other end to ur dvd player and put it one the wire that is to be connected to the 12v for the revarse camera the wire should be orange but urs might be a different color.
Nov 28, 2010 | XO Vision XOD1735 Car DVD Player
Security Camera
it is important to know model and make or camera if you want a solution
Jul 09, 2009 | Home Security
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
