Question about Toys
Lemax Victorian Christmas stopped working. Hi purchased thislast and was working fine. This year it suddenly stopped working. When plugged to power nothing happens. Tried to change adapter same thing
  • 62 Answers
SOURCE: computer won't reboot
Hi, I can help you with this. What shows on the screen when you power it on?
Posted on Sep 16, 2007
ctf1800
  • 4402 Answers
SOURCE: won't turn on
*Unplug the AC cord
*Remove the battery
*Locate the memory cover on the underside of the notebook
*Unscrew the one or two screws securing the memory cover, and lift up to remove the cover
*Gently slide (away from one another) the metal retaining clips that hold down the module.
*The module should pop up
*Remove the module
*Reinstall the module (removing and reinstalling the module is apparently enough to rectify the contacts)
*Replace the module cover and the battery
*Attach the power cord
*Try to power up
Posted on Jan 21, 2008
SOURCE: won't power up
Im having the same problem, however I have a remote with my laptop and I can power it on using it. After a lot of research the most useful information I've found is at http://www.experts-exchange.com/Hardware/Laptops_Notebooks/Q_23091890.html
I'm also having the issue with audio, no speaker sound but headphone jacks work fine. Looks like i may be replacing the power button. No warranty here.
My model: HP dv6119us
Posted on Feb 22, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Thinkpad T43 wont get any AC power
I've run into this many times with IBM machines. The power management chip on the motherboard has failed. Unfortunately, you will have to replace the motherboard in order to fix the problem.
Posted on Aug 13, 2008
SOURCE: HP Pavilion dv2500 no display when power lights not blinking
Hello
To get the display on the TV . Please press Fn + F4 after connected TV to the Notebook using Svideo cable and the cable should be connected to the Svideo port of the Notebook.
If there is not display on the Notebook after the Svideo cable burns.
Then please perform the following steps.
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If the issue persists then check whether the display is same on the external monitor.
I hope this will work.
Thanks
Posted on Aug 24, 2008
Can I buy a replacement light mechanism for the Lemax lighthouse?
This is an electrified display village like one uses at Christmas or for a toy train set- not something we normally see in Automotive. Try this web site: http://www.ehobbytools.com/contents/en-us/d17.html
and good luck
Jan 03, 2015 | Cars & Trucks
No sound
Check your sound system in options, if everything is fine its something about amplifier on digital board, you need someone to make measures
Dec 05, 2013 | Televison & Video
Gateway ZX4300 - power adapter problem
Verify all specifications of your previous charger and new chargers/adaptors.
Jun 24, 2013 | Computers & Internet
Lemax village express adapter
Lemax Item #74706
Lemax does sell 4.5V @1000ma adapters. They are usually in the accessory section with the light sets. It will supply power for up to 3 devices. Notice this adapter is rated at 1000ma. The adapter that was included in the set was only 700ma. That just means that the replacement adapter can handle a larger current draw, IE. the train and a couple 4.5v accessories.
It works. I am using one now.
P.S. Walmart has these adapters..
Jul 11, 2012 | Lemax Collection Village Express Train
Wii doesn't work after a month
It is best if you return it for a warranty repair or replacement in this case as any attempt to repair or open this unit will void your warranty.
It should be under a 1-3 year warranty for your type of product so you should be safe returning this item unless it was purchased second hand.
May 26, 2012 | Nintendo Wii Black Console
Amplifier unit of MHC-W770AV stopped working all of a sudden.
Start with the simple things first, hunt round for fuses near where the mains goes in. Keep on the lookout for anything that looks burned or broken. If there's no power to anything it will be something in the power supply section.
Apr 12, 2009 | Audio Players & Recorders
Doesn't work
There is a small switch at the same end as the ac adapter plugs in. Makes sure that is in the on position. If still nothing...try to get another ac adapter. Even if the engine was bad..the lights would come on if the track got power.
Dec 23, 2008 | Lemax Collection Village Express Train
No power
Since this generator quit working suddenly it's likley that something is wrong with the field circuit inside. The metal surfaces you cleaned off sound like the slip rings of the rotor, there should have been 2 graphite square rods mounted on the plastic bit you took off that ride on these slip rings, they could be worn down or broken.
You'll need a good DMM to measure the resistance between the 2 slip rings (should be about 15 ohms), also measure each of the stator coils (black and white wires in the molex plug) look for an open.
Because the generator has been sitting for a couple of years it probably also hsa lost its residual magnetism, you'll need to flash the field to get it working again once all the parts are confirmed to be OK.
Oct 07, 2008 | Coleman Powermate Powermate 5000W...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
