FWR59WA my tv switch on picture is present but no color is present
Samsung ps42a457 picture disappeared whilst watching,sound still present
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Televison & Video
The color fades in and out. Presently, no color. Everythin is black and white. But the color flickers from time t time.a
The problem of your tv. is some of the parts in your pcb has already a weak connection try to tap the side your tv. if the color returns try to resolder the crt socket section it is connected in the picture tube. But before you open the back of your tv. and do the soldering be sure to unplug it to prevent accident.
May 17, 2011 | Proton MM3601VT 36" TV
How do you make a pincushion adjustment. Picture is OK in center but out of focus as it spreads out in all direction with a bow shape at bottom. All colors appear to be present. Can you help?
This is not adjustable,have dead parts.The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment anywhere in the pictures,have colors pictures shadows or 3D pictures look alike?The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 23, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Cannot get a signal from presenter to tv
Have you selected the EV 308 button on the video selector switch panel. If you have and still no picture, the camera or the switch assembly could be faulty. Try hooking up a VCR or a DVD player or video camera to one of the "Video in" teminals and select AV1 or AV2 . If you get a picture through to your TV your camera on the presenter is faulty.
Nov 26, 2009 | Office Equipment & Supplies
Red coloring on my tv
There is a problem with the color "guns". In a cathode ray tube TV there is one for each color. A sharp jolt can misalign these guns or the voltage on one may have become much larger than the others.
DO NOT attempt to fix this problem yourself. Extremely high voltages are present on and around the picture tube, where the magnets for the these "guns" are located.
HIGH VOLTAGE persists for WEEKs after the set is powered off. Consult a qualified TV technician.
Oct 06, 2009 | Zenith B27A11Z 27" TV
Screen is Perfect just Black and White only...No Color
well a dvd player is only going to playback the media it is reading. So if the dvd is a reproduction of a b/w western then b/w is correct but if you play a dvd from the present then it should be in color unless the tv it is connected to is faulty. Try connecting to another tv to see if problem repeats on another tv
Aug 15, 2009 | Protron PD-800 DVD Player
Picture and sound problem at 21" sony waga color tv
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
Feb 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
White picture
You could have a electrical short in the picture tube or a short in the circuit leading to two of the three color guns.
Mar 12, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
