Have LP 2824 - prints okay but after 20-25 labels it continuous feeds labels until powered off or spooler cancel?
Print smaller batch and after appx 20-25 total same feed happens. Liquor POS using built in template editor to edit label. need to set roll media. Any help appreciated.
SOURCE: LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Posted on Nov 09, 2007
  • 28 Answers
SOURCE: Continual feeding of labels?
the settings of the printer must have been changed
Posted on May 24, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
SOURCE: Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Posted on Apr 11, 2009
  • 62 Answers
SOURCE: Hi can you help ? My zebra TLP 2824 printer keeps
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Posted on Nov 20, 2009
Zebra eltron LP 2824 printing too light
This could simply be old direct thermal labels. Direct thermal labels have a shelf life of about 1 year from the date of manufacture. After that time has lapsed the thermal coating on the labels begins to dissipate and this will cause labels to print light or faded. You can trouble shoot with a roll known to be fresh. You can get one free here to test Labeldomain com .
If this does not solve your problem then please check this article on 5 common print quality issues and how to correct them Fix Zebra 2824 2844 3842 print quality
Jan 28, 2014 | Zebra Eltron LP 2824 Thermal Printer
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Zebra LP 2824 Plus Giving Endless Labels
OK where is the print spooler on the remote client or the server. Have you check whether this is clearing and not an issue with your remote setup and not the printer does the printer work correctly attached directly to the server break the problem down in stages
Dec 07, 2012 | Zebra LP 2824 Plus Thermal Label Printer
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
My lp 2824 zebra printer is printing too light
I am unsure if this one is a ribbor printer or a thermal......
if thermal the paper might be too old or the print head is going bad. if ribbon try replacing the ribbon, or you have a bad batch of ribbons.
Jan 04, 2011 | Zebra LP 2824 Printer
What is the best way to clean the printing "head"?
Use a Thermal Printer cleaning card. I get mine in with my labels. First turn power off on the Thermal Printer. Insert the card into the feeding path, press form feed or manually pull the cleaning card using both hands until the entire card has been pulled free.
Nov 18, 2010 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2824 not printing a barcode
check the driver if the length and the with are correct, print a test page, check if come the windows logo and the test from all label. check if the barcode is biguer that the label, if it is, is not appear.
2 solution is to reset printer to factory defult (press button until flash 4 times and relese the button.
Aug 19, 2010 | Zebra Eltron LP 2824 Thermal Printer
Zebra lp 2824 faded printing
Many factors affect print quality: Heat settings, speed setting and label face stock quality and type are a great place to start. How old is your printer? How many labels have been printed through it (there is an odometer that tells your this on the config label). Is the printhead dirty? Use > 90% isopropyl alcohol on a cotton ball or microfiber cloth to gently clean the printhead.
I would start by checking the heat and speed settings in the driver - crank up the darkness and crank down the speed a notch or two at a time until you get the print quality that you are looking for. If all of this fails, you may need a new printhead (not too easy to replace on this model). Printheads are made up of an array of resistors. These can loose their electrical resistance over time and require more energy (controlled by the darkness setting) to get the same results as a new printer. Printheads, like labels and car tires are considered a consumable commodity.
Jan 14, 2010 | Zebra Eltron LP 2824 Thermal Printer
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
27 people viewed this question
