Question about Breville Coffee Makers & Espresso Machines
I have a breville wiz mix. The switch is faulty and I want to take a look. How do I open the casing?
Breville one cup filter kettle intermittently switches off before boiling . It will work if I keep the button depressed.
Oxidized or worn thermo-switch contacts.
Or, sometimes old age (kettle!:) or overheating can cause springy contacts to bend out of shape.
Get tech-minded person to open/inspect & renew as required.
Jan 19, 2017 | Breville Kitchen Appliances - Others
We got a berville kitchen wiz as a wedding present in 1963. The handle on the bowl has broken. Can you let me know if I can get a replacement bowl for this product.
Contact Breville with the model number and ask them, don't hold your breath though they change models regularly.
Sep 14, 2014 | Food Mixers
Breville vkj628 on off switch faulty
Parts for these items are often bespoke and impossible to find.
The best option is to replace the kettle with a new one.
Jul 14, 2014 | Breville SK500-XL Stainless Steel Cordless...
Machine won`t turn off unless unplugged and continues to draw water.
can be 2 possibles faulty: 1) the main switch 2) control board faulty
repair or replace in any cases.
God bless you
Oct 09, 2013 | Breville Die Cast 800ESXL Espresso Machine
Blinking AC button of Honda Civic 2003
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
1.Turn the blower fan OFF.
2.Press and hold the recirculation control switch and the rear window defogger switch down.
3.Turn the ignition switch ON (ll).
4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
- If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
- If the system is ok, the recirculation indicator stays off.
DTC (Recirculation indication blinks) Detection Item Page
7An open in the air mix control motor circuit.21 - 16
8A short in the air mix control motor circuit.21 - 16
9A problem in the air mix control linkage, door, or motor.21 - 17
10An open or short in the mode control motor circuit.21 - 18
11A problem in the mode control linkage, doors, or motor.21 -19
12A problem in the blower motor circuit.21 - 20
13A problem in the EEPROM in the heater control panel;
14An open in the evaporator temperature sensor circuit.21 - 23
15A short in the evaporator temperature sensor circuit.21 - 24
- In case of multiple problems, the recirculation indicator will indicate only the DTC with the least number of blinks.
- In case of an intermittent failure, the heater control panel will store the DTC until the ignition is turned off.
Mar 17, 2013 | 2003 Honda Civic
Need plastic timing belt drive pulley for Breville BB 380
I may have a machine you can use for parts. I have a BB380 which mixes the dough OK but trips the electrical core balance switch in the house when it goes to bake - so I was taking the pan out and bakeing it in the gas oven. But I got tired of resetting all the electric clocks in the house and bought a new machine. Would this be of assistance?
Jul 13, 2009 | Kitchen Appliances - Others
Why is the grind from my Breville BCG450XL in the finest position coming out like a drip grind with a fair amount of dust mixed in? I have an old Solis with exactly the same conical burrs which is grinding...
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Feb 20, 2009 | Breville BCG450XL Manual Burr Grinder
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
