Question about Refrigerators
Where is the interior light for the fridge freezer 23RI-D4PT
    Top Expert:
  • Refrigerators Master
  • 50,211 Answers
Under or behind the clear /opaque plastic cover
Posted on Dec 12, 2016
  • 1 more comment
  • Doug Lumley
    Doug Lumley Dec 12, 2016
    Thanks, Ray - I can't work out how to open it, though. Any hints?
  • Doug Lumley
    OK - Got it! Right hand rear cover. Retained by two vertical "plugs". Lever downwards. Problem solved - Cheers!
  • ray gallant Dec 12, 2016
    simple enough when we try eh
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
Temperature control panel
CHECK THE ON/OFF SWITCH ON THE INSIDE.
Jun 17, 2015 | GE Refrigerators
Fridge freezer not working and fridge interior light comes on but is very dim
There is an Evaporater fan located in the back section of your freezer and depending on year of the fridge supllies the air flow to the freezer and fridge section and may use a circuit board or may not. On Fridges newer than 2002 they use cuircit boards prior years do not. The power to the evap fane is shared with the light in your freezer and a locked up fan can cause no cooling and draw too much amperage and cuase the light to be dim. My suggestion before trying to diag is go to www.aplliancepartspros.com and look up your fridge by model number and locate the diagrams for the freezer section and you will have a better idea what you dealing with.
Sep 24, 2012 | Refrigerators
Green light does not come on for settings 0 to 4
the ice cream is the clue,if it goes hard then the temp is too low (ice cream best kept at -18C)
either the defrost is not working or interior temp sensor duff.
Mar 26, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
INTERIOR LIGHT GOES ON AND OFF
next time it does this unplug for 20 mins and pcb will reset its self....
Sep 28, 2009 | Hoover HFA290K Bottom Freezer Refrigerator
The power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old
Hi Boatgc,
You say, the power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old.
Is the freezer also not cold?
If the fridge is not cold and the freexer is!!!
There are a couple things to sheck.
Let me know!
Huuum
Sep 21, 2008 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
