Question about Coffee Makers & Espresso Machines
Coffee onl running for 5 seconds then off again have to keep pressing
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
Tip
How to calibrate a Bunn CWTF commercial coffee brewer
1. you need a 64 ounce graduated measuring cup or bucket
2. make sure the brewer is heated up to temp and the green light on the front is lit
3. open the front panel of the brewer
4. put the microswitch on the circuit board to "unlock" position
5. make sure the sprayhead is cleaned and open, the brew basket is on, and the measuring cup is in place to catch the water
6. press and hold the brew switch until the inlet solenoid clicks 3 times, then release
7. once the water level is at about 40 ounces, turn the main red switch off and let the rest of the water come out
8. if it brews short, press and hold the brew switch again until the 3 clicks, then press and release the brew switch for 2 more second of brew time (up to 5 times per brew)
9. if it brews too much, press and release the brew switch for two less seconds of brew time (up to 5 times), then press and hold the brew switch until the 3 clicks then release
10. once you get to 64 ounces, put the switch on the circuit board to lock and replace the panel
11. enjoy!
on Jan 15, 2015 | Bunn CWTF 15-APS Coffee Maker
Nespresso U - the lights keep flashing but doesn't work
have you done descaling try pressing the two buttons at the same time but keep holding them for 5 second tell me is it flashing fast or slow?
Sep 08, 2014 | Krups Nespresso U Xn250a40 Coffee Machine
Miele reset system
I have a Miele CVA 4085 built-in coffee maker. I found a post on how to get into the programming menu, which on the CVA 4085 is this:
  1. Open the door and switch off the power with the rocker switch on the top left.Wait at least 5 seconds.
  2. Switch the rocker on then VERY QUICKLY close the door and hold the clear button for 5 seconds.
  3. With your other finger touch the ON button then pull both fingers away at the same time.
  4. Do 5 rapid presses of the clear button but hold your finger down on the last press and keep holding it down until the programming menu comes up.
  5. Do not press the reset button that you see at the top of the menu (unless your German is quite good or you have access to Google Translate).
  6. Scroll down until you find the reset cleaning button (or whatever you want to reset) and select it. Once you have confirmed you can then exit programming mode by powering off.
It took me quite a while to get to this point, but at least I can now recognize the German word for drip tray.
Sep 07, 2012 | Miele Coffee System
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
May 13, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Keurig onle dispenses half a cup
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Oct 25, 2010 | Keurig Elite B40 Coffee Maker
How do I reset the oil service counter
1. Switch ignition OFF.
2. Press and hold button "A" - fig. 1 or fig. 2.
3. Turn ignition key to position "I".
4. After 5 seconds the words "OIL SERVICE" or "INSPECTION" are shown together with the message "reset" or "re".
5. Release button "A". Press and hold button "A". After a futher 5 seconds the message "reset" starts to flash.
6. Release button "A". Press and release button "A" again.
7. The new service interval is now displayed.
8. Press and release button "A". The message "END SIA" is now displayed.
8. Switch ignition OFF.
Fig.1
Fig.2
Aug 27, 2010 | 2004 BMW 3 Series
How do I pre brew
I got one of these for xmas, and I was able to program the pre-brew option.
First, turn off the machine.
On the front of the machine, there is series of 5 buttons. (From left to right, they are: Small Coffee, Large Coffee, Pre-ground Coffee, Hot water and Descaling.)
While holding down the 1st (Small coffee) and 4th (Hot water) buttons, turn on the power.
Wait 3-5 seconds before releasing these two buttons. You machine is now ready for programming.
Below the 5 buttons are 4 small lights. If the second light from the left is red, the machine is already programmed to pre-brew. If the light is not red, do the following:
Press the Coffee button (2nd button from the left) once and the second light from the left should glow red. This turns on pre-brewing. (Pressing the Coffee button again will turn off both the light and the pre-brew option.)
Now turn off the power for at least 5 seconds. The next time you turn the machine on, it should pre-brew the coffee.
The process worked great for me the first time, but when I wanted to program the machine to not pre-brew, I had to go through this process a couple of times. Not sure why, though. :-)
Kathy
Jan 13, 2009 | Saeco Incanto Classic Espresso Machine
Reset ge model 169165 electronic cleaning cycle
Unplug the coffee pot and push in the "1-4" and "TSB" buttons at the same time, hold the buttons in for a few seconds. This will reset the pot and you should be able to brew like normal after that.
Dec 07, 2008 | GE 106591 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
