Loose wire in wall control unit cable under control unit in brivis AD11 evap cooler
  • 182 Answers
SOURCE: evap coil drip tray leaked
2 contractors.hvac first.
Posted on Aug 05, 2008
louislevel_2
  • 374 Answers
SOURCE: burn out circuit board
hi! there! replace the burn out circiut board,what ever you pull out the same thing you put back just be sure that has the same model and specification,calibrate and test overload protection,defective overload protection replaced to prevent any burn out,short circuited mostly came to burn those thing that's why imposing preventive maintenace schedule for this kind of large ac central unit is very much significant.mostly timer delay circuit malfunction on large scale unit supplying by three phase a/c source on central control panel board.when ever replacement occured try to put mark or list color coding of specific terminals to connect and isolate short circuit make possible to detect at once before installing the new one and make make record on this for future reference we have several cases like that after buying a new one and replaced still burn again,the common cases is that they did not find the cause of short circuit connection they just relay on circuit board burn out,so it better to make assured that every thing is fine before installing the new one.specially on supply source of circuit.,relay on diagram and manuals take and check all data source as reference this will be a great help.take all necessary precaution this should be done by qualified technical ac support,have a nice day and regards
Posted on Mar 31, 2009
  • 68 Answers
SOURCE: Honetweel heater control unit failing
you would have to study the wirring diagram etc but any gas heater control should work, you just have to know how to hook it up as the ignition etc is all incorporated in the control
Posted on May 03, 2009
SOURCE: Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
Posted on Jun 06, 2009
  • 3 Answers
SOURCE: Our fan on our brivis evaporative cooler is not wo...
there is a fan insert with a part Number 17517 this insert sits on the shaft of the motor. my fan is working but not blowing so i went up on to my roof and found out that this particular insert is broken (due to a birds nest )
Posted on Jan 29, 2011
The heater is not displayed on the wall remote.
The modern Life., You'll need some how to track it down. However, are the batteries in the remote Fresh? I mean to ask, how old are they? And, are the sensor lenses clear of whatever?
May 02, 2014 | Heating & Cooling
Brivis evaporative cooling
you have an reset on the contoller,try it.
Dec 05, 2013 | Heating & Cooling
Last night my Brivis evaporative cooler didn't seem to be working very well. I left it on low overnight and when I got up this morning, the system is no longer working and there is no display on the...
Yes the evap coolers do need maintenance just like all other air conditioners,
The end result of controller no longer working is indicating there is now a electrical issue.
You should contact a Air Conditioning mechanic for a breakdown.
Jan 25, 2011 | Heating & Cooling
Our brivis evaporative cooler won't start.The on/off switch only gives a beep but the screen is blank.
could be the control box in the unit. could be a faulty controller. most likely to be a damaged lead. mice like to eat them. It may have a very small amount of damage.
Jan 08, 2011 | Mastercool 67471 Evaporative Cooler Air...
Our fan on our brivis evaporative cooler is not working. The pump to fill it with water is working and the fuse is fine. what else could it be - the unit is on the roof and I can not get to it.
May 17, 2010 | Heating & Cooling
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
May 12, 2009 | Heating & Cooling
May 03, 2009 | Honeywell Programmable Thermostat Heater
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
