Question about ASUS Computers & Internet
ASUS G10AC-US009S header schematics - ASUS Computers & Internet
Adapter schematic
if u want schematic of laptop adopter then u should sell first what is the volt of adopter is generating for your laptop.
then you search on google.
Nov 28, 2013 | ASUS Computers & Internet
Schematics of the asus k52n mother board
There is no schematics available unless you have access to the internal asus-sites. These are only for Asus-techs. Describe your problem, I can troubleshoot the issue.
Jul 11, 2013 | ASUS Computers & Internet
Good day i have mother board asus p5800-mx the usb port cannot work theirs no 5 volts in the port, pleas help me to resolve my problem thanks.
Ashley,
A) There are two USB headers on the motherboard.
They are rectangular in shape, and Blue in color.
One is to the immediate Right of the 3 white PCI slots.
Has 4 pins across the Top row, and 5 pins across the Bottom row.
May have USB56 printed on the motherboard next to it.
The second one is at the Bottom of the motherboard, below the Intel 82801EB southbridge chip; which is to the left of the CMOS battery.
May have USB78 printed next to it
http://www.ebay.com/itm/Asus-P5P800-MX-Socket-775-MotherBoard-NEW-865GV-/221041609289?pt=UK_Computing_LaptopMotherboards_CPUs_CA&hash=item33771b4a49
(Turn motherboard photo 90 degrees to the Left, to be as it sits in your computer case)
EACH USB header supports TWO USB ports.
A Card Reader uses ONE USB header, with it's two cables.
Point?
Front Panel USB ports, are connected to one of those blue USB headers.
This USB header you know to be bad.
If the other USB header is not being used, connect to it.
The front of your computer is the Front Panel.
The USB ports in the Front Panel, should be connected by one common cable, and it ends in a plug on connector.
No? Not feasible?
Then suggest using a USB adapter card, in an open white PCI slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&CatId=511
Product details indicate it has two internal USB headers.
This way you can connect the Front Panel USB ports to it.
http://usa.asus.com/Motherboards/Intel_Socket_775/P5P800MX/#download
Choose ANY O/S, and then download the manual.
Or, here is the direct link to the motherboard manual (PDF file),
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5P800-MX/e2005_P5P800-MX_V2.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P5V800-MX Motherboard
My ASUS P5N7A-VM Motherboard doesn't show a cd-rom in bios it shows my hard drives and an A: which I don't even have so what do I do?
Your not giving enough info..
Have you replaced the motherboard ?
Are you useing one or two IDE cables. ?
If you are useing one cable, the hard drive should be set to master and the cd dvd drive should be set to slave.
If two cables are used, set the Hard drive to master and the other drive two slave or cable select.
Oct 01, 2009 | Computers & Internet
Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Aug 11, 2009 | ASUS Intel 5000P Chipset...
Searching the s/pdif socket on motherboard
hello, i have looked over the schematic,the header should be marked spdif,(small white lettering) right next to or between the pci slots,or near the audio chip. it will be a small black connector. hope this helps,good luck!
Mar 15, 2009 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
