Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Not making ice as fast as it once did!!
My ice maker has stopped procucing ice like it used to , it is now very slow! Where do I look to solve this problem. Thanks Tim
  • Whirlpool Master
  • 1,606 Answers
Check the coils under fridge to make sure they are clean .
Posted on Jul 21, 2009
Ice Maker very slow to make ice. In weeks time, with minimal use, ice hasn't covered the agitator.
Mine doesn't but they do warn that low water pressure will slow down the cube maker.
Feb 15, 2016 | Whirlpool Refrigerators
Icematic n131m
The more activity the freezer and fridge see, the more cold escapes. If the freezer defrost system gets issues (broken defrost heat coil, stopped up vents, frozen peas in coils) things slow down. Find the defrost timer and mark the knob on it with white-out to see if it moves. It moves very slowly, one rotation a day.
Nov 26, 2013 | Kitchen Appliances - Others
Ice make has stopped making ice
Good day, lots of reasons an ice maker will stop making ice. Just take a step by step procedure and it will solve the problem.
The freezer must be at normal temperature. At least 12 degrees or colder.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Jun 23, 2010 | KitchenAid KSCS25FKSS Side by Side...
RB 215 ice maker not making ice very fast? Was great for awhile now using more ice it just can not keep up. No manual
they can only freezer water just so fast. they will not keep up with heavy demand for ice it will only harvest ice about once an hour
Apr 10, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
Mar 15, 2010 | Kenmore 51lb. Clear Ice Maker
Ice maker working very slow , it's still making ice every once in a while, but very slow
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
00
Sep 22, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Amana SZD26VW about 10 years old - no water or ice
probaly the water inlet pump behind the fridge is defective or the filters are clogged I'd change the filter first if this dosen't help i'd say change the water inlet pump
May 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
296 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
