I do not have the old v belt the model hcwp 1102 washer
2 Suggested Answers
  • 700 Answers
SOURCE: Where can I buy a replacement V Belt for my Home Comfort HCWP 1102 washing machine?
same question, same answer...
you did not supply country, or location - telepathy do not work, nobody can help if data is not known.
i would suggest any store selling belts (automotive, tire places, white goods repairers and suppliers), just grab old belt, take it with you and salesperson will be able to determine from the numbers on the belt what length and profile of the belt will be and will sell you happily replacement.
Posted on Jan 22, 2015
Washer not spinning laundry all the way, still very wet.
Take the old belt to an auto parts store and have them match it. Unless it some kind of special design an automotive belt should work.
Feb 02, 2016 | Speed Washing Machines
Jan 22, 2015 | Washing Machines
Where can I buy a replacement V Belt for Home Comfort HCWP 1102 washer?
Where to buy a drive belt for borletti 1102 sewing machine
THIS IS AN OLDER MACHINE SO BELTS ARE A POSSIBLE PROBLEM BUT DON'T WORRY. TAKE THE OLD ONE OFF AND GO TO YOUR LOCAL REPAIR SHOP AND SHOW IT TO THEM. THEY WILL BE ABLE TO GET YOU ONE THAT IS VERY SIMILAR AND THE RIGHT LENGTH.
Nov 17, 2014 | Sewing Machines
I have an old kenmore washer, on which I cannot find the model number. It needs a new drive belt. The only information that I have is that it is marked as a Kenmore Heavy Duty 80, and inside the door is...
Go to a local Sears or Whirlpool store and tell them you have an old "belt drive" Kenmore washer that needs a new belt. All of these were built by Whirlpool Corporation and I believe used a common belt.
Good luck.
Mar 25, 2011 | Washing Machines
There is a rubber burning smell during the spin cycle on my stacking washer/dryer applicance. It is about 10 years old. How do I open the applicance and check the belts during the spin cycle?
This is a drive blet problem
To replace the drive belt, you will need to open the access panel or in some cases tip the washer onto its side to expose the belt on the bottom. Start by removing the back cover, and look for a belt. If you do not see a belt (or a place for a belt - the belt itself may have broken and is hidden from view) and you can see the floor then your washer is a direct drive model that does not use a belt. If you cannot see the floor because there is a steel floor in the washer, locate the motor and determine if it extends through the bottom plate. If so, then the belt is accessed from beneath the washer.
If you have to tip the washer over, place a large piece of cardboard on the floor to protect the floor and the washer's finish. Because a washer is pretty heavy, you will need an able-bodied assistant to safely tip the washer onto its side. Also, there will be some water remaining in the washer, so have sponges and towels ready to clean up any spill.
To remove the old belt unscrew the clamps securing the pump coupling ( a leathery or rubber flexible part that connects the motor to the water pump). Remove the pump coupling to slip the old belt out. Some models instead require you to loosen the motor mounting bolts and shift it inward to relieve tension on the belt. Remove the old belt.
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.
Replace the cover and test the washer for proper operation
Sep 29, 2009 | Kenmore Washing Machines
How to replace a belt on a washer
On some washers, mostly older models, a belt is used to transfer power from the motor to the transmission and pump. If that belt breaks, the washer will not operate properly but it will make sounds like it is doing something. If the belt slips or is loose, the washer may operate sporadically or erratically. It may make loud squealing noises and there may be a burning smell. Some models use two belts, one for the transmission and one for the pump.
Replace the cover and test the washer for proper operation.
Thanks for using fixya
Regards
PCmania
Sep 27, 2009 | GE WBSR3140DW Top Load Washer
Change the belt on the machine
Usually the easiest way is to put the belt on the smaller pulley first and then start it on the bigger pulley on one side and then turn it onto the bigger pulley by spinning the pulleys to get the belt to direct itself onto the larger pulley little by little. Using a flat-headed screwdriver can help pry the belt on and keep it from falling back off of the larger pulley while turning it to get the belt fully on. If you have any other questions about this, let me know.
Benjamin
Jun 15, 2009 | Kenmore 22422 Top Load Washer
I have a GE top loading washing machine. Model #wjrr4170gww. I need to replace the belt and can't seem to get the belt on. I know it is a tight fit, but my question is what is the trick to get it on.
Dear Customer,
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.Replace the cover and test the washer for proper operation.
Thank You for using Fixya.. Good Luck!!
Jul 10, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
