Question about Cell Phones
Unlocking my sim slot - Cell Phones
HELO!PLEASE CAN I GET A HELP? MY LUMIA521 CAN'T READ SIM CARD.
Remove back cover and remove battery and check sim is properly fixed in side sim slot or not. If sim is loose inside sim slot then put some paper packing make it properly fixed also remove sim and rub with cotten lock the golden part of the sim and insert again. Also check the sim in another mobile and if in that mobile sim also not recognized then there is issue with your sim card replace it.
here is how to sim unlock mobile http://mobile-cellphones.blogspot.com/2016/06/android-smartphone-sim-unlocking-details.html
Jul 21, 2017 | Cell Phones
Where do I put the sim card
Hi you can insert your sim card in the sim slot found at the back of the phone in some model mobiles sim slot will be found at the side or top of the phone ...Before inserting the sim you first check that whether the phone is unlocked to accept your network sim or not ..If the phone is locked to network provider other than one which are you going to use then the phone wont accept your sim until you unlock it ..You can easily unlock the phone using network unlock code ...You can purchase code from online providers like UnBBLock.com here they are rendering network unlock code for all blackberry mobile models at reasonable cost .Else if you want to unlock some other mobile model then visit sites like Unlock-Zone.com here they are rendering network unlock code for all mobile models at reliable cost ..After unlocking the phone you can freely use it with your sim ....
Dec 09, 2014 | Cell Phones
Where do I put my sim card in this phone
Unlock sim slot fot zte v793
How to unlock simcard slot for zte v793
Sep 21, 2013 | Cell Phones
Insert sim
What is your mobile model?To insert simcard,the following conditions should be satisfied....
1)The mobile should be unlocked to accept the sim card
2)The mobile should have the sim slot (most CDMA phones do not have that provision)
3)The simcard size should be supported by mobile phone.
Now,if your mobile is locked with a particular network then you need to unlock it.For that you can either approach the respective network provider or third party unlocking services like Simpleunlocking.com or unBBlock.com (This is specifically for Blackberry phones) and unlock your mobile.Once your mobile is unlocked the sim slot will either be in the side or above or below the battery depending on your mobile model.If you search in Google you probably will get a more clear idea about where your sim slot is located.Once you find the sim slot remove the sim card and note down the position; replace it with the old sim card(it should support the phone sim size specification).
Jul 12, 2013 | Cell Phones
How to unlocking verizon lte-cmda samsung galaxy i515
I am having a Samsung Nexus SCHi515 with Verizon network( It has a sim slot)
I have taken the phone to India. I thought it could be unlocked and used in some CDMA network( Reliance) here since one of my friend have unlocked LG droid 3,(non-sim model),verizon network. But I have heard from some people that phone with sim slot cannot be unlocked and only the non sim model can be unlocked and registered with the Reliance CDMA network in India.
Is it not possible to unlock the model with sim slot?
Kindly help me out.
Aug 09, 2012 | Samsung Galaxy Nexus Sch-i515 - 32gb -...
My i68+ says emergancy calls only and insert sims after it is in
Unlock code is 1122. But check to see if the sim is inserted correctly. Open both sim slots first. The bottom slot should have the sim inserted with the gold bars facing up. The top slot should have the bars on the sim facing down.
May 21, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Unlocked
what phone company was the phone using before you unlocked it (sprint) ?? that slot you are looking at is probably a memory card slot not a SIM slot. everything im reading says that phone is not a GSM phone aka it doesnt take SIM cards
Feb 05, 2009 | Audiovox PPC 6700
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
