Question about Tablets & eReaders
I can't find power button on Emerson 4.0 tablet
My 749 Emerson tablet has a pattern lock and I forgot it, my user name and password, what do I do?
You will need to Factory Reset the tablet. Warning: You will loose everything on the tablet and it will be wiped out completely, returning it to the day you took it out of the box.
1. Turn unit off
2. Hold VOL+ and the Power button at the same time for a full 5 seconds then release both. A dead Android bot should show.
3. When the bot shows, again, hold the Power and VOL+ together, then release VOL+ first, then the Power button last.
From here, you should see "Android System Recovery" on the screen.
4. Used the VOL+ and VOL- to scroll through the selections to pick "wipe data/factory reset" and press the Power button.
5. Use the VOL buttons to move to "Yes - delete all user data" and hit Power to select.
6. Use the VOL buttons to select Reboot now and hit Power.
Once complete it's as if you opened the unit for the first time out of the box.
Mar 18, 2016 | Tablets & eReaders
Unlock my Emerson tablet EM744
emerson em744 factory reset instructions July 18, 2014Uncategorized
Emerson em744 factory data reset - southern telecom, Emerson em744 factory data reset if you have set a password on your tablet and forgotten the password, follow the instructions below to reset the tablet.
How to hard reset emerson tablet? - the tablet has a, My girl locked her emerson tablet how do i unlock it.. foegot password emerson 543? would like to hard reset my tablet videocon vt75c. i had tried the options.
Where is the operating manual for emerson tablet mmem 744, How do i hard reset my emerson tablet em744? i had my ereson m744 connected to the pc to charge and when i unplugged it, it was locked. i have not established a. How to reset an lcd tv ' ehow, Navigate to the "factory reset" or similar wording option using the arrow keys on your tv's remote control or on the front panel of the tv. press the "ok" or "enter.
Gsistore.com, (2) 04a42-015b-05 120v 4" bracket only (2) 405-043a 120v 4" blade only (2) 501-138b 120v 4" motor only 02a42-009a lock strike for sm models 02b01-085d door assembly.
How to connect wireless headphones to a pc ' ehow, Test the headphones. pick out a song or a video and play it on your pc. connect your wireless headphones and verify that you can hear the audio..
5 home depot hacks - buzzfeed, 5 home depot hacks. home depot may not have swedish meatballs, but it can be the ultimate store for affordable, durable, modern furniture if you know how to hack it..
Amana top load washer service manual - scribd, This base manual covers new double front panel series, top load wash machines. refer to individual technical sheet for specific information on models..
Stirling engine design manual - scribd, Stirling engine design manual 2nd edition this design manual provides an introduction to the stirling cycle heat engines. it analyzes compares non proprietary engine.
Mar 29, 2015 | Tablets & eReaders
Fully charged Emerson tablet won't power up when power is pressed.???
Check your power button.
If possible, try with another button.
Oct 11, 2014 | Tablets & eReaders
How to reset an emerson em744 tablet?
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 25, 2014 | Tablets & eReaders
Screen wont unlock em744
There is a small hole in the back of your tablet with an "R" or "Reset" next to it. Put a paperclip into the hole and hold it down for half a minute, it should give a little as you are pressing a button inside the hole. When you turn the screen over you will either see only a blank screen or the word "Emerson". That is the tablet going through the shutdown process don't be concerned if you see either as the word only stays on for a short time. Let the tablet sit for 3 or 4 minutes then try to power it back on by holding down the power button. You should see a screen after a few seconds that says "Emerson" that will have a rotating partial circle under it. This should complete your reset. If this doesn't work then you are most likely having a hardware or firmware problem and need to take the tablet back to your place of purchase for support.
Dec 01, 2013 | Tablets & eReaders
Emerson tablet hard reset
With the unit powered on, you unplug it from power source.
Then push and hold the power button for about a minute. THEN, replug back in and turn on. And cross your fingers.
Aug 07, 2017 | Tablets & eReaders
Emerson tablet
Hold the power button down for about 8 seconds to force it off. Hold it till screen goes dark. Don't release if "power Off" dialogue pops up. Keep holding it to force off.
Apr 16, 2013 | Tablets & eReaders
Emerson EM543 is lock by pattern code and i cant unlock it
Try this first (If you setup an email account for this tablet)
Enter 5 incorrect passwords
You should see a "Forgot Password?" button, click it
Follow the prompts and it will help you change your password.
If not...
This solution works for most tablets.
Power off the tablet
Tap Power, then press and hold Power + Vol Down until you get a menu, then release
Look for a Recovery or Factory Reset option, and select it.*PLEASE NOTE THIS WILL ERASE ALL DATA, INCLUDING THE PASSWORD*
Feb 02, 2013 | Barnes & Noble 5010960439 Emerson Quote...
Emerson tablet touch screen is frozen. How do I get it to work?
There is a tiny reset hole on the back of the tablet marked with a "R" near the SD card slot. Push a small paper clip in the hole until you feel it hit the button. This will reset the tablet and the touch screen will start working again once you power it back up. --Emerson m744 android tablet.
Dec 04, 2012 | Tablets & eReaders
Tablets & eReaders Logo
32 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
