Question about Refrigerators
Looking for side bracket door hindge - Refrigerators
2 Suggested Answers
  • 6277 Answers
SOURCE: bracket for door broke need
FixYa is sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 15, 2011
Change the door swings
Many refrigerator (especially the really old ones) have universal hindges. Check the top of your fridge if there are nut holes in the opposite side of the door hindge. These holes should corrispond to the same bolt/screw holes used on the hindge side. If so then you can remove the door by first removing the bottom hinge bolts. Have another person hold on the door and remove the top bolts. You only need to remove the bolts that go into the main body of the fridge. Put the door down on a table or flat surface and remove the rest of the hindges. Keep track of the bolts as they may differ from the ones in the fridge. Remove any screw caps/covers from the other side of door and use them to cover the old screw holes. Switch the hindge to the opposite side of the door and secure. Lift the door in place and remount the hindges to the opposite side of the old hindge mounts. Secure and check closure. There should be enough play in the hindge mounts to adjust for a good close. Tighten and cover all screws and openings with the old covers.
Note: If you can't get a good seal then check the gaskets for warping. You may need to replace them if they are too deformed.
* Check your warranty. You may have a tech come out and check everything. Perform annual maintenance and have the gaskets changed out. You can also have them change the door to swing out the other way since they have to remove the door to change the gaskets anyway.
Aloha, ukeboy57
May 28, 2018 | Refrigerators
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
How do I adjust the 'feet/roller' at the rear of the unit in order to ensure the unit is level?
there are two allen head type screws one under the freezer door hindge side one under fridge side hinge insert a large allen wrench long handle type and turn clock wise to adjust the back wheels be carefule if you turn counter clockwise the long screw will come out of the adjustment nut in the wheel bracket. then have some one tilt the fridge back and next to the allen wrench you will see a white disk that is the adjustment eor the eront of the unit turn it clockwise it will spin down as you turn it.
Jun 28, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
How to remove doors on samsung side by side refrigerator
We always unbolt the top hindge cover,and unbolt the hinge and lift the door off of the bottom hinge.Hope this helps,if so give us a 4 thumbs up. THANKS
Mar 04, 2011 | Samsung RS2630SH Side by Side Refrigerator
How do i put the oven door back on after i removed it to obtain measurements. now i can not get the door back on
I had the same problem today I found that you have to extend the hindge enough to have the lock tabs lock into the door to hold the hindge in the extend mode. If the tabs are not back in the door it will continue to snap back. After you lay the door in place be sure to extend the lock tabs back up into the oven side towards the pins that you hindge lay on. WATCH YOUR FINGER TIPS!!!
ken@mobilevapor.com
Nov 14, 2010 | Ovens
I had extensive front right side damage due to a accident, the good news is that I was able to get the parts I needed at a fairly reasonable price from LKQ (aftermarket), however I'm a single mom trying to...
the hood is made of a pretty flexible Aluminum alloy, should be fairly easy to bend back, if there arent any creases. And the Hood Brackets are pretty simple to bend back, because they are made of a pretty maliable metal as well, you can probably use a hammer and wood block to bend it back. good luck, and dont bungee the hood any more! JK
Mar 14, 2010 | 1998 Toyota Corolla
Dome Light blows fuse within minutes
Hello , check the door open actuator . This is the " button " looking switch on the door jamb . It maybe on the hindge side or the latch side. It may be shorted.
Jul 14, 2009 | 2001 Nissan Maxima
Want to reverse door handles
On most you take the top hindge off. Lift the door off the bottom one then remove the bottom hindge.
May 09, 2009 | Refrigerators
Can't open door
inspect the door hindge pins and busings it sounds like they are getting worn out and maybe due for replacement. also look and see if the spring in the hindge is still their. if all is well have the door adjusted properly to repair your problem.
Mar 22, 2009 | 1996 Chevrolet Tahoe
Frigidaire follow up side by side door noise.......
ok these hindges are confusing but the hinges that came with it are not in right place
example top bottom
bottom top switch them they should match door geometer of made holes
one bracket on bottom door fits on bottom bracket
the top bracket goes on top of the door to hold the door in
May 17, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
