Question about Samsung Televison & Video
I have a Samsung LCD TV UN48J520DAFXZA and the picture has suddenly gone very dim.
I can barely see it. I have had the TV for about 6 months. I can get new circuit boards for $60. Do you think this would fix the problem or should I just buy a new TV?
thecritter
  • 29 Answers
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Posted on Mar 30, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
ginko
  • 19396 Answers
SOURCE: Sony LCD TV has Dark Picture
the problem is not the lamp.
This model has a set of two backlight lamps, and it is practically impossible that both lamps go faulty at the same time.
When the backlight lap in an LCD TV goes off in this way, the faulty part is always the backlight inverter, that is the high voltage board powering the lamp.
In your case you have to get the TV inverter booard replaced.
Posted on May 30, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
mislamy15m
SOURCE: Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Posted on Aug 28, 2011
The display panel LCD light has gone dim on my Samsung model SMH2117S. How do we fix it to restore its brightness?
1st sep go to menu,setting,picture and go brightness colloms rediuse the dim full line if not may be your screen is damage you can by new L E D tv.this old L C D tv panel is too much cost
Feb 07, 2018 | Samsung Computers & Internet
My samsung 62" tv has no picture/have sound
Darken the room. Very dark. Turn tv on. Press menu button. Get flashlight and shine at screen. If you can make out the menu barely. It's the back light gone. Is it plasma or lcd.
Jan 01, 2018 | Samsung Televison & Video
T Con Board or a panel problem? Can this be fixed?
With most models LED LCD TV of Samsung brand have T'Con board is a built in panel type. If so; it is not replaceable. Panel replacement is necessary, if this is the case.
Dec 10, 2015 | Samsung Televison & Video
Why is my tv screen a dull white color?
T'Con board fault. Replace it. Will look like this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 13, 2015 | Samsung Televison & Video
Dim screen on HP. Any diagnostics I can run to isolate the problem?
The problem is in the inverter board, "located below the screen" or the backlight behind the LCD display is faulty. In most cases the inverter is the issue and replacement only option, "be aware that high voltage is present when running"
Apr 15, 2012 | HP Compaq nc6220 Notebook
Picture suddenly dimmed and i have not had the t.v. for 7 months with limited use. I checked all the settings and nothing seems to brighten the picture. One instant the the picture was great. I come home...
It could be the lamp, they have an approximate 1 year life depending on conditions. If you bought the TV new, it has a 1 year warranty and labor you might want to contact warranty support. They will send you a new lamp.
To Receive a Replacement Lamp Under Warranty
Call (800) 553-7278. Please have model number, serial number, and TV purchase date available.
Important: All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect
verification.
Appendix C of the manual describes how to change the lamp. Handle with care (avoid fingerprints on the new lamp). Make sure the TV is off for at least an hour before starting.
I hope this helps.
Jun 28, 2010 | Mitsubishi WD-65731 65" HDTV
17 month old set; Picture gone. Direst TV repairman says it's the backlight bulb. Others say it's a Board.
it might be inverter board it is not backlight bulb according to my expertise bcoz once it goes off it dont come back
but u see inverter and CCFL backlight bulb failing symptoms are so same that u cant simply distinguish but i am sure u have one of these two problems inverter is more chance
Kindly rate me well
Regards
Zohail
May 23, 2009 | Vizio VX42L 42 in. LCD TV
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
52 people viewed this question
Jerry Greenberg
Jerry Greenberg
