Question about Norcent Technologies LT-3250/LT-3251 32 in. LCD Television
Problem turning TV on
TV will not come on unless I hold the power button down until the picture is on. If I don't hold the button down, the TV just shuts off.
  • 11,896 Answers
This may be a faulty power supply or control circuit board. Further diagnosis would have to be done to pinpoint exact problem.
Posted on Jul 20, 2009
My tv has sound but no picture
Try this:
Unplug it and everything plugged into it.
Hold the power button with it unplugged, then plug it in whilst holding the power button.
Hold the power button down until something happens.
This might reset the tv
Apr 05, 2017 | Televison & Video
Won't program to our new TCL television - we have the 222 receiver
I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 14, 2011 | DISH Network IR Remote Control
Sieki television code for dish network
I don't show a code for that brand of TV, however, you can perform a power scan to see if you can find a code on the remote that will work. Power scan instructions below...
  4. Press and release the Up or Down Arrow button once every second on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
Hope this helps!
Aug 11, 2011 | Televison & Video
I need remote codes for vizio vbr231 blue ray player as well as a teac home theater receiver AG D9260
We don't have codes for the Vizion Blue-Ray player but I have provided instructions on how to perform a power scan.
    3. Press and release the TV Power button.
Aug 06, 2011 | DISH Network IR Remote Control
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
PS3 hdmi generates a not supported format error message on my emerson lcd tv
your ps3 is set to work on a 1080p tv you can change the pixel setting on your ps3 by holding the power button down while youe console is running until it turns off let go and hold your power button down again when your console turns back on your tv wil ask you about the hdmi device its found unless you failed, good luck n00bs
Jan 10, 2010 | Emerson Televison & Video
How reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Aug 31, 2009 | RCA RCR815 Remote Control
VS 5001R sounds like its gonna turn on but doesnt
This chassis model line had issues with the vertical output IC shorting causing shut down.
It also had issues with intermittent solder connections in the Horizontal Circuit. I would not try to fix it your self unless you are very familiar with Projection circuitry and electronics background.
Hope this helps,
Skyassoc
Jul 02, 2009 | Televison & Video
Rcr4358 have the code but how do I program it in I don,t have a :code search button: which button do I use?
Hold down the tv and power button until it turns red
Then press play once the light will blink once it stops if the t.v. has not turned on press again then continue until the tv turns on.
Press reverse until tv turns off
Hold down stop until light goes off
Apr 02, 2009 | Televison & Video
PRIMA HT2778P pin-cushioned blue screen - service menu reset needed
Try this one:
1. Unplug your power cord from the box (NOT THE
WALL!)
2. Wait 3-5 min... No more than 5 MIN (very important)
3. Hold down the power and select button at the same time and don’t let go.
4. Have someone plug the power back in… and keep holding the power and select button.
5. Don’t let go until it gets to 0 (it's about 5 min)
6. Once it gets to 0 then it will stop counting down, that when you let go!!
7. Don’t touch anything,
8. The screen will reset and it will go blank. nad that's it
Hope that helps....
Jul 10, 2008 | Televison & Video
Norcent Technologies LT-3250/LT-3251 32 in. LCD Television Logo
182 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
