Question about Panasonic Microwave Ovens
How to install part number F891P6F00SAP door open button on Panasonic microwave NN-SD297
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
  • 178 Answers
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Posted on Sep 13, 2009
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
SOURCE: Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Posted on Nov 24, 2010
joeguest2
  • 2080 Answers
SOURCE: My Panasonic NN-SD297 microwave is
To deactivate the DEMO MODE on your Panasonic microwave, just press the CLOCK button on the control panel 3 times.
If you were successful, then the display panel will go blank and will no longer display the 'DEMO MODE PRESS ANY KEY' message.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Posted on Sep 24, 2011
Panasonic NN-SD297 shuts off after 15 sec and refers me to the operating manual. What's wrong?
Don't believe it's anything you can repair if you don't have some knowledge about Microweves and doubt that manual can enlighten you. Your device is defective and should be repaired by an competent microwave technician.
Jul 04, 2015 | Microwave Ovens
Door release button does not work
busted plastic part in microwave send model # we can find the part you need
Feb 20, 2015 | Panasonic NN-SD277WR - NN-SD277WR...
Door release does't work
It may be a broken door open button, door open lever, or grease in the channel where the door open button moves in the control panel frame.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You can order Panasonic parts from Encompass here but without part numbers, it may be best to call them toll-free at 866-779-5835.
Dec 20, 2011 | Panasonic NN-H275 Microwave Oven
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
http://www.searspartsdirect.com/partsdirect/part-model/Panasonic-Parts/Microwave-Parts/Model-NNSD297SR/0789/0123370/50036271/00001?blt=06&prst=0&shdMod=NN-SD297SR
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
Looking for a service manaul for a panasonic NN-SD297 microwave
See this link.
(I understand this is an old post, but answering it now may help someone later.)
Jan 11, 2011 | Panasonic NN-P295SF Microwave Oven
Jan 19, 2010 | Panasonic Microwave Ovens
Hi, I just installed the NN-SD297 OTR microwave. I must have done something wrong. I have steam and a bit of grease running down the wall. Looks like it might be coming from Behind by the rear bracket. It...
Sounds like you didn't block the top vents. If it is not vented the top vents must be blocked and a carbon filter added . The metal plates you added don't appear to be air tight.
Oct 27, 2017 | Panasonic Microwave Ovens
Microwave Ovens Logo
73 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
