Where can I find setup motherboard key? - Computers & Internet
What Motherboard? I can find your answer on the Motherboard makers website.
Posted on Dec 17, 2016
In bios how do you access settings in intelligent tweaker
To access the BIOS Setup program, press the <Delete> key during the POST when the power is turned
on. To see more advanced BIOS Setup menu options, you can press <Ctrl> + <F1> in the main menu
of the BIOS Setup program.
Once in the MIT menu CTRL+F1 should show you more advanced options also.
Mar 22, 2012 | Gigabyte GA-G31M-ES2L Motherboard
Will not bootinto bios
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
hope this helps youi
Sep 23, 2011 | Biostar N68S+ Motherboard w AMD Phenom X3...
Main bios checksun error bios auto recovering
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Sep 11, 2011 | Gigabyte GA-G31M-ES2L Motherboard
The INTEL Motherboard Logo screen is not passing,,
The key to enter setup should be DELETE or F2.
Jul 23, 2010 | Intel D865GBF Motherboard
Bios problem i m getting in error windows loading
Typically to enter setup you only need to tap either F2 or the Delete key as soon as you turn the computer on. The splash screen will usually tell you which is the correct key. It may be called 'setup', 'BIOS' or 'BIOS Setup'. Hope this helps,
www.PuterCare.com
Jul 07, 2010 | Mercury P4VM800M7 Motherboard
1 What are the POST ErrorBeepCodes-2 Key sequence to eneter SETUP
Do a google search on Bios Beep Codes for the first, and to enter the BIOS setup, most PCs use the DEL key during the self-test. Some others use the F2 key. Most detail that, on the bottom line of the display during the post sequence.
May 07, 2010 | Intel Motherboard
I would like reset the password of my d33005 motherboard
Go into the BIOS setup to reset the password. Start by rebooting the system. Before the system starts loading the operating system, the computer will give an opportunity to enter the BIOS setup utility. Usually a screen appears saying to press a key to enter the setup utility; i.e. "Hit DEL to enter Setup". You have to know what key the computer is looking for to get to Setup. DEL in used on the a lot of ASUS machines but you may that to refer to a manual or read the screen just before the operating systems to load. Once you get in, look for something related to security settings. Once it is found under the boot tab. Here is where you can reset the motherboard password. Hope this helps.
Dec 15, 2009 | ASUS Computers & Internet
Chack sum bois bad
1. change the Bios battery
2. restart your computer
3. press Del key or F2 key to enter in Bios setup, and save the bios setup at Best performance or
Default setup...
try this..
Jun 20, 2009 | ASUS K8V-MX Motherboard
My usb controller is not enabled i cant use the usb ports..
go to the CMOS setup of your motherboard. to do it turn on your computer, and it will display in your screen to press a certain key such as del or f1 or f10 key to access the CMOS setup. once inside the CMOS setup, look for the enable USB controller. enable the USB controller then waaala. your USB controller is now working.
Dec 22, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
Mach MSNV-939 motherboard - RAID 0 - How to setup?
im in the same spot... di anyone found this sol. ?
Apr 10, 2008 | Mach Speed (MSNV-939) Motherboard
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
