Question about Alcatel Cell Phones
How do iunlock sim slot on my alcatel - Alcatel Cell Phones
I have a Alcatel & a TZE T126 phones I took the sim card out of my alcatel which works with the sim placed it in my T126 phone & a message says no sim why if it works on my Alcatel
May be One of the phones is on an other (prepaid)account the sim is not recognized and the phone was not unlocked? a little suggestion.
Feb 22, 2018 | Alcatel Cell Phones
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Sim positions on Alcatel 1045D.
Remove back cover and you'll see the battery. Remove the battery and you'll see the SIM card slot
Jun 17, 2017 | Alcatel Cell Phones
Alcatel 1054D sim card positions
Under the battery, there is the SIM card slot.
Alcatel one touch sim stuck in sealed phone, no tray just a slot next to the SD card holder. Can anyone please help me if they know how to get it out??
can you take a pic of the slot and how the sim card is stuck in there? Have you tried a small needle in there to see if you can catch the end of the sim card and then pull it out?
Jun 09, 2016 | Alcatel Cell Phones
Slot permanently locked
Hi Alison,
Try this site..
http://sim-unlock.net/simlock/Alcatel/OT-5020T/
Choose your model and follow the steps. You may have to purchase a code to unlock it.
I would strongly suggest you take it back to where you bought it as you locked the phone by inserting a different SIM. You activated the security feature to prevent it from being used. At this point you need to get the vendor to unlock it... try calling the place where you bought it, and see if they can assist first. Best of Luck!
Feb 25, 2014 | Alcatel Cell Phones
Hw to get network key to unlock alcatel ot708
You can get the Network Unlock code for the ALCATEL OT-708 model Phone from here
Classicunlocking.com and Unlock it from Network lock using the instructions below.
Alcatel OT-708 One Touch MINI Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Alcatel OT-708 One Touch MINI mobile phones. If you enter over a certain amount of wrong unlock codes on your Alcatel OT-708 One Touch MINI mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Alcatel OT-708 One Touch MINI with a NOT ACCEPTED SIM Card,
2 - When the message "Enter Network Key" appears, enter the Unlock Code.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Alcatel OT-708 One Touch MINI is locked to.
OR
1 - Switch ON your Alcatel OT-708 One Touch MINI WITHOUT SIM Card,
2 - Then compose : *#0000*CODE#,
3 - To finish compose : *#0001*CODE#.
CODE: The unique unlock code for your Alcatel OT-708 One Touch MINI.
Aug 06, 2011 | Cell Phones
Cell Phones Logo
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
