Question about Bissell Vacuums
My Bissell 2x carpet shampooer Keeps clogging with sand and some pink gel like stuff
  • 432 Answers
SOURCE: carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. I hope this helps:)
Posted on Jul 15, 2007
  • 1673 Answers
SOURCE: bissell carpet shampooer
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Posted on Jun 17, 2008
  • 107 Answers
SOURCE: bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Posted on Dec 15, 2008
SOURCE: Repair manual for Bissell 2X ProHeat 9200 Carpet cleaner
Bissell Manual
Posted on Feb 24, 2010
  • 43501 Answers
SOURCE: bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Posted on Sep 30, 2010
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
Very little suction leaves rug wet.
Check tank and tubes for clogs. Make sure your belt and brush are working. Also make sure you are not overfilling your tank.
GoodVac com
Feb 24, 2015 | Bissell 2X Proheat 9200 rug cleaner
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have a Bissell Pro-Heat 9200 2X Carpet Shampooer. When you start to shampoo the carpet it runs water for a minute and then quits and won't spray any more water.
I can not solve it, but have had the same problem with 3 of their shampooers. I am on my 3rd one. Have taken it back to be repaired and it still does not work. Thank God we bought the extended warrenty and they have replaced them. Now my newest one that I have only used 3 times is having the same problem.
Jan 30, 2011 | Bissell Vacuums
Brushes not spinning on my Bissell carpet shampooer (pro heat turbo 2X)
Dog hair may cause this, clean this unit, take sissors and cut hair.
Feb 14, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Using Bissel proheat carpet shampooer. Have used
No, you don't dilute it. And yes, it does use a lot of formula!
Apr 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer priblem
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes.
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Shampoo won't **** up water on carpet
try seeing if your lint filter is clogged. you will find this in the upper section of the water tank.
Sep 17, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
The solution in our bissell carpet shampooer will not come out what can we do?
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jun 21, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
29 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
