Question about Photography
How do I get my pics loaded onto digital photo frame to show in the right orientation? Show correctly on computer before loading to flashdrive. Reformatting to FAT not an option that shows available
Trouble getting photos in right orientation onto digital photo frame.
SOURCE: 7 digital photo frame problems
Yeah, I just got one too and I have no USB thingy, and I kinda need my memory card.... hmmm.... maybe it should come with one. That's a bright idea huh! And how on Earth do you get music on it?!
Posted on Dec 26, 2007
SOURCE: 7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Posted on May 12, 2008
  • 5 Answers
SOURCE: Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: Cannot find how to load photos onto Dolphin 1.5" Digital Photo Frame Key Ring
I had the same problems but solved it by uninstalling the useless POS software, rebooting the computer and reinstalling everything.
I have found that you have to do this everytime that you want to add or delete photos. Probably the worst piece of software I have seen in 15 years of working on computers.
If it won't detect as a seperate drive in "My Computer" then you will have to uninstall it and start again.
There is also no need to format the device. Just ignore it and start downloading photos and it worked straight away. (Using XP Home) As to battery life, I suspect I will never know because it is liable to have a visit from my sledge hammer before it runs out of power.
Posted on Dec 26, 2008
SOURCE: I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Posted on Jan 02, 2009
Make photos show with correct orientation on digital photo frame
sir,
Your camera may be having more options of orientation or keystone or resize etc, if it is set to such options the picture results as you said, please try to re set your camera to factory default. then you try the photos effect.
Jan 31, 2016 | Cameras
Pictures oriented incorrectly
the order and way these photos are stored/retreived is different between units..as long as they get displayed thats all that matters..
Jan 15, 2014 | PixiModo Reflection 15M 15-Inch Digital...
My Grandma was given a Coby dp700 with pictures already on it for a gift. She would like more pictures. I can get different pictures from a usb flash drive to play as long as the flash drive is plugged...
Most digital frames come with a USB cable to hook the frame directly up to a computer. When you plug in the frame, a drive should show up in your "My Computer" section (for Windows) or on your desktop (for Mac). In most cases, you just need to drag and drop the photos onto the drive.
Mar 05, 2011 | Coby DP-772 Digital Picture Frame
Hi, I have been loading pics onto my new Digital Photo Frame. I've loaded the pics just fine, however, the pics will slide by just fine, then the next slide says "No Support", then I have pics,...
Hi bon_kahlua_r,
It means that your Digital Photo Frame might not have support for the file formats of some pictures that you saved. Most Digital Photo Frame supports *.jpg formats. Please check the manual of your Digital Photo Frame as well as the files that your saved. Right-click on the pictures that are not supported then Click Properties. You should be able to see the file format of the picture then compare it to the Frame's manual if it's supported.
Thanks
Feb 22, 2011 | Computers & Internet
Hello, is there a way to transfer the pictures from the digital frame memory card to a flashdrive or computer? My puppy chewed my camera memory card and I would like to transfer the pics fromt the digital...
You will need a card adapter for whatever card is in the digital frame. Then just use the adapter with the card and you can save the pictures onto your computer. Adapters are usually no more than 10 dollars and local stores.
Jul 08, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Dec 30, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Photography Logo
124 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
