Question about Car Audio & Video
Pvx15 ampli power is not on light flicker only
MY SOUNDCRAFT EFX8 IS CAUSING MY AMPLIFIER LIMITER TO KICK IN, AND CAUSING SOUND CUT OUT
Usually is because the signal exceed the input limit of the ampli.
I don't know which ampli do you use, but it should be a pro ampli with balanced inputs correctly able to manage +4 dB professional signals.
Try not to exceed 0dB in the master section of your mixer and let me know.
Oct 14, 2015 | Soundcraft Music
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
IS YAMAHA AMPLI RX SERIES RIPP OFF
Maybe the problem is with your speakers. Shorted speakers or speakers that are being over-driven can cause the receiver to shut down and possibly be damaged.
May 21, 2013 | Yamaha Rx-v465/rxv465 Home Theater...
Is yamaha ampli rip off ?
I have not personnally had any problems with any yamaha recievers, or surround processors that I have ever purchased, and they continue to operate these decades later. The fact that they have pre-amp outputs for all channels was a major determining factor, as I could then use other amps with more power for expansion. make sure you have a surge protector for your ac power supply, that has been the biggest source of problems with any piece of a/v equipment
May 21, 2013 | Yamaha HTR-5660 Receiver
The light yellow is on what hapen whit my ampli
Depending on what light it is. It could be your ohm light, if it is your ohm light then you have something wired incorrectly. If it is another light, it could either be a power problem or it could be that your amp is damaged.If you would like, you may e-mail me and u can let me know which light is on. It SHOULD say right next to the light; which light is on. E-mail me at epayne123@yahoo.com and I will respond to you as soon as i recieve it.
Oct 30, 2009 | Jl Audio 300/4 Car Audio Amplifier
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
Queme las salidas del ampli
abrelo i quita las alidas i ponle unas nuevas i busca aver si no quemastes mas cosas
May 30, 2009 | Pioneer GM-X262 Car Audio Amplifier
Spl car audio ampli ext-2000d no power comsuption
Read through the following page (particularly the section on troubleshooting a dead amp).
Amplifier Repair Primer
Let me know if you have any other questions.
Aug 09, 2008 | SPL Dynamics XL2-1600 Car Audio Amplifier
Problems with the ampli
can i joine the ampli with computer
Oct 17, 2007 | Autotek XS-900.2 Car Audio Amplifier
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
