Question about Samsung 7.5 Cu Ft Capacity Platinum Gas Front Load Dryer - DV42H5200GP/A3
Gas dryer. Samsung DV42H5200GP 7.5 Cu. Ft. Gas line connected, but not in on position. Is there a pilot to be lit? If so, where located?
  • Samsung Master
  • 2,791 Answers
No pilot...
Yours is a "hot surface" electric igniter ...
The link (below) should take you directly there...
(picture is just for viewing ... Retailer sales site)
Please be advised... gas appliances must be externally vented & installed in a manner as NOT TO THREATEN human life.
EVEN if you are having a HIGHLY QUALIFIED technician install, inspect & operate your equipment... The instructions should be completely read & understood by EVERY USER.
ADDITIONALLY it would be VERY WISE to consider getting a carbon-monoxide detector ...
Like your life depends on it.. because it could...!!
Be safe.
http://www.appliancepartspros.com/samsung-heate-dc47-00022a-ap4211272.html
Posted on Dec 12, 2016
  • 3 Answers
SOURCE: Maytag DG612 gas dryer does
unplug your unit.You have an ignitor no pilot. Just because they glow they are not good. Do you have a meter and an amp clamp? Test all the limits and thermisters for continuity. If you find one with no continuity it is bad.
Posted on Jul 13, 2008
  • 53 Answers
SOURCE: DRYER IS ON, AND SPINNING, BUT WITH NO HEAT. GAS
check the high limit thermostat or thermal fuse. any of these break it will not give power to the selonoids to turn on
Posted on Nov 05, 2009
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
SOURCE: Dryer lights works, but when
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Posted on Aug 14, 2010
  • 146 Answers
SOURCE: i have Samsung-7.3 Cu. Ft. 7-Cycle Electric
i would take the plug panel off the back and make sure you are getting the full 220 volts on the terminal,, (it could be in the cord itsself), if that is not your issue, it might be your main board, since it is new i wouldn't tear into it because it will void the warranty
Posted on Jan 28, 2011
Why is my timer not counting down, and no heat?
Make sure the vent and heater air intake are not clogged with lint. Also, check the gas pilot to make sure it is not blocked up with gas line sediment, and the ignitor is working properly. The timer is probably waiting for a signal from the flame sensor.
May 08, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Gas converion
Since no model number was given, gas dryer conversion kits usually come with instructions. The usually require you to replace the burner orifice, and make an adjustment to the regulator already included with the dryer. In some cases speacial tools are required to perform the conversion. Pleazer Appliance...
Apr 08, 2014 | Samsung 7.3 Cu. Ft. 7-Cycle Gas Dryer -...
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
The gas had been turned off. how do I relight the pilot?
Shut gas valve off and let it air out. You can see the pilot with the little rod on it. Turn valve to pilot position and light a lighter to light the pilot. Hold the valve for a minute. If it stays lit, then turn valve fully to the ON position.
May 14, 2011 | Kenmore 500 6952 Dryer
The "Control Locked" is lit up and the control
Try holding down the CONTROL LOCK button down for about 3 seconds.
See if that works.
Comment back here if it doesn't and I will provide additional instructions if required.
Good luck.
Joe.
Feb 27, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Our dryer does not heat as a result of temporary flooding in basement....is there a pilot light on this model?
haven't been pilot lights for a number of years.  it could be a number of things including the ignitor, gas valve or thermal fuse.  i would start with the thermal fuse and then the ignitor..
Jul 29, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer runs fine but does not heat
Check that the pilot light is lit and flame kicks on when dryer is activated. If no flame, then check gas valve. If only pilot remains lit but does not increase when dryer is activated, then you could have a bad coupler or sensor or circuit problem which would have to be tested with a voltmeter and/or test light.
Nov 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Gas pilot not lit in dryer.
It has an electronic igniter,Just make sure the gas is turned on the the dryer(at the valve located behind it)and make sure the power cord is plugged in.
Please rate this a fixya
Feb 03, 2009 | GE DBXR463GB Gas Dryer
Samsung 7.5 Cu Ft Capacity Platinum Gas Front Load Dryer - DV42H5200GP/A3 Logo
48 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
