I would like to know how I could hook up a kirsch model k3 woofer but no speakers
dnewcombe1
  • 1564 Answers
SOURCE: lost the remote for a kirsch k3 home entertiament
If your unit is not listed within the list of acsess codes, you will have to find it the old fashioned way. Code search is available on all multi function remotes. It takes awhile but it will eventually work. You might also try going to the manufacturers site and check in the "support" option or the FAQ's Thanks, Dana
Posted on Feb 13, 2010
  • 60 Answers
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
  • 10 Answers
SOURCE: I have a harman/kardon computer
If you turn your pc around, so that you can see the back. There should be a series of small coloured holes - each of which has an image. From there you can plug in the corresponding wires for L and R speakers and the bass (subwoofer)
Posted on Mar 03, 2011
SOURCE: ilost my remote for my kirsch k3 and i don't see a
'ai besoin une remote pour un receiver fm et am kirsch loud speackes k3 pouvez vous m'aider svp
Posted on May 18, 2011
SOURCE: can you program a dvd player to a kirsch loudspeakers k3 remote control?
Can you program a dvd player to a kirsch loudspeakers k3 remote control?
Posted on Apr 03, 2013
Kirsch k3 codes
tengo un bluray marca lg y quisiera utilizarlo para controlar dicho dvd y quisisera que me proporcionaran un codigo
Jan 12, 2014 | DISH Network IR Remote Control
Need code for kirsch k3
These are the codes to check. 4435 4450. If you wish to get more, http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 05, 2013 | One For All URC-3021 Remote Control
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
ya u can connect the dvd player to the loud speaker it is simple there is one connectivity port in the dvd player u can connect through that
Sep 14, 2012 | Cell Phones
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
I want to install a self powered woofer and tap it to the rear speakers. Can you please tell me what are the colors and polarity of the rear speaker wires for 2006 Honda odyssey right hand drive
FIRST OF ALL --- THERE IS A FEW THINGS YOU NEED TO KNOW BEFORE HOOKING UP
A WOOFER LIKE THIS ---- IS THIS A STORE BOUGHT POWERED SUB WOOFER ? DOES IT HAVE IT'S OWN CROSSOVER BUILT INSIDE ?? I WOULD GUESS IT NEEDS TO BE HOOKED
UP TO A SUB WOOFER OUTPUT FOUND ON THE BACK OF THE IN DASH PLAYER ..
THE WOOFER NEEDS TO RECEIVE ONLY LOW FREQUENCY AUDIO WHICH MOST OF THE NEWER CAR STEREOS PROVIDE BY AN RCA JACK ON A SHORT WIRE COMING OUT OF THE STEREO ...
IF YOU TRY AND TAP IT TO FULL RANGE SPEAKERS THAT ALREADY ARE CONNECTED TO AN AMPLIFIED SIGNAL THE SOUND WILL BE DISTORTED .......
POWERED SUB WOOFERS NEED A LINE LEVEL INPUT WHICH IS MUCH LOWER THAN SAY
SPEAKERS ALREADY RECEIVING AN AMPLIFIED SIGNAL.
POWERED WOOFER WILL ALSO NEED TO HAVE A 12 VOLT ELECTRICAL CONNECTION AND A GROUND WIRE TO OPERATE THE AMPLIFIER BUILT INSIDE.
IF YOU HAVE NO EXPERIENCE WITH THIS TYPE OF HOOK UP I WOULD STRONGLY RECOMMEND SOMEONE WHO DOES [ CAR AUDIO SHOP ]
Jun 29, 2011 | Car Audio & Video
Cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Ilost my remote for my kirsch k3 and i don't see a code with to program it with the other remote that i went out and purchased
Feb 13, 2010 | Electronics - Others
Need wiring assistance
Just need to register, login and you can download manual from here.
It will take only two minutes.
Hope this helps.
Apr 26, 2009 | Bose Acoustimass 10 III System
57 people viewed this question
 Grubhead
Grubhead
