Question about Home
Have kidde smoke alarm i12080a lite won't go off on second alarm other one is ok why is lite staying on?
The safety lite is the lite staying on no green lite no beeping
  • 4 Answers
SOURCE: my kidde smoke and carbon monoxide alarm keeps
You will need to remove the unit from the ceiling to reveal the battery compartment on the back. It should just need to be rotated counter clockwise a small amount and will then come loose from the bracket. When installing a new battey be sure to press the battery reminder finger down into the battery compartment or the battery door will not close. Call the Kidde (pronounced kid-a) hotline if you have problems 1.800.880.6788
Posted on Aug 05, 2009
SOURCE: kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Posted on Feb 28, 2010
  • 13 Answers
SOURCE: kidde smoke alarm won't stop chirping
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Posted on Mar 23, 2010
  • 13 Answers
SOURCE: I just fixed a new Kidde alarm hardwired with both
The normal condition for the green LED is solid. A flashing green LED indicates memory of a prior alarm condition. Press the test for at least 2 seconds to reset the detector memory.
  • 10 Answers
SOURCE: I have a Kidde combo smoke/carbon monoxide alarm
I assume your alarm is hard wired which should have its own circuit especially if there are any fluorescent lights on the same circuit.
Posted on Sep 01, 2013
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
Will Kidde wireless smoke alarm model interlink with Kidde wireless smoke and carbon monoxide model
According to the Kidde website, model KN-COSM-B-RF can interconnect with "Up to 24 devices (of which 12 can be smoke alarms)", so I would say the answer is "yes". The Kidde website also offers a place where you can submit questions...I'm sure they would be happy to help you. Kidde KN COSM RF Battery Operated Wireless Interconnect Combination CO and...
Aug 09, 2015 | Home
Locate battery on kidde home smoke detector to change battery ?
Kidde Dual Sensor Battery Operated Smoke Alarm PI9010
25436074-0u3vpaqtlkylcnuyowrcgmo2-1-0.jpg reference: http://www.kidde.com/home-safety/en/us/products/fire-safety/smoke-alarms/pi9010/
Feb 16, 2015 | Home
I have a Kidde Life Saver Smoke Alarm.Is the light suppose to stay green ?
The light is supposed to flash green approximately every 30 seconds or more, just to let you know it's working
Jan 29, 2015 | Home
My Kidde Frynetics 1275 smoke alarms started going off intermittently. (Slower than when there has been smoke in the house from the oven). THere was no fire and no smoke. Not sure why?
Make sure to only use a brand name alkaline 9 volt battery. Don't use a used battery or a dollar store battery (bargain store). Then press the test button for 10 seconds to reset this unit and any more down the line.
Oct 28, 2013 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My Kidde carbon monoxide alarm keeps beeping every 30 seconds and we have put new batteries in it but it keeps beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 09, 2012 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
I just replaced 3 old interconnected Nortron AC 12W smoke alarm with 3 kidde direct wire 120V units- ( no battery back-up) when i turn the AC breaker on- all three Kidde chirp every 10 seconds. I ...
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
Jul 24, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Hello I have a KIDDE FYRNETICE smoke alarm.
According to the Kidde website, this unit was discontinued in 2010. If the unit is more than 10 years old it must be replaced per NFPA 72 (assuming you live in the US)
Dec 22, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Home Logo
99 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
