Contributor
- Posted on Apr 05, 2010
Re: Base unit on bt synergy 3505 keeps beeping and...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base.
The following procedure should be followed to help resolve the problem:
- Confirm that the power lead has not been inadvertently disconnected from the base.
- Ensure that the handset batteries are correctly installed and are fully charged.
- Ensure that the handset and base are within range of each other.
- Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
- Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
- If none of the above remedies solve your problem, please contact the helpdesk.
