Question about Maytag Washing Machines
Maytag washer doesn't get rins cycle - Maytag Washing Machines
Maytag Neptune TL washer doesn't stop adding water
it sounds like your drain hose is to low it needs to be 3 feet high if its to low this will cause the water to syphon out and keep refilling
Nov 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Maytag Epic Z 400-The water doesn't pump out @ the end of a cycle. I assume the pump is clogged how do I open the front of the machine?
Remove the three screws on the lower front panel. The panel will slide down and out of the way. Next twist the filter handle and pull the filter out of position. Clean the filter and run a test cycle. That should fix your washer friend, good luck.
May 19, 2011 | Maytag MHWZ400T Front Load Washer
Washer won't drain
Check your drain and filter on the washer. It is most likely clogged with debris.
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Maytag Stackable W/D
well htere is a fuse, its located right behind the washers front panel on hte right hand side. its an inline fuse( you can find at hardware or auto part store FUSE (250V 1A) , but this would stop all operations not just water fill. With the front panel off you can "see" through the machine to the filll valve and check it for poower when the "fill" is selected, I would point to a bad water valve or even a faulty prssure switch( not allowing power to the valve befoer condeming the timer.. the pressure switch is also located on the front rail by the fuse assembly anbd will have a plastic'rubber tube connected to it, i would disconnect and blow through the tube for possible obstruction.. ( if the pressure switch is satisified., the machine will think there is wate rin the machine and therfore wont allow anymore to enter.
Dec 27, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
