Question about Sony Televison & Video
Apparently after relocating the Sony kdl40v2500 fr an upstairs room to another room on the ground flr, the screen even though still has a picture has fine vertical lines throughout??!! Any ideas?
    Top Expert:
  • Sony Master
  • 75,452 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Dec 12, 2016
  • 20 Answers
SOURCE: Black Vertical line about an inch wide right of middle - PFM-42V1 Sony
The problem is the actual PDP panel address chips blown or a faulty ribbon cable to the PDP or if your lucky it may be a dry joint - Tap the ribbon while the set is on very lightly on all cables with something plastic and see if the black line goes away - if so your lucky and its an easy but fiddly repair.
Posted on Aug 25, 2008
mistersony
  • 320 Answers
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Posted on Oct 18, 2008
abhishek33
  • 1239 Answers
SOURCE: lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Posted on Jul 04, 2009
  • 30 Answers
SOURCE: SONY KDF E50A10 vertical multi-colored lines across the screen
bad Q box, need tech to replace
Posted on Aug 09, 2009
circuitworld
  • 335 Answers
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Posted on Nov 09, 2009
2 level townhome- the upstairs is heating to 68 degree-thermostat is located but the downstairs is like 58 degrees.The vents are open in ceilings downstairs. How can we do to get more heat downstairs
close ceiling vents
the hot air down stairs rises through the vents and adds to the upstairs heating
same as hot air goes up the stairs to the upper rooms
Dec 27, 2017 | Heating & Cooling
Sony bdps360 grainy picture issues
Unfortuneately the problem is in the RF circuits after the laser,but combined in the whole assembly. There is nothing you can do, except if warranty applies take it back.
Mar 13, 2012 | Sony BDP-S360 DVD Player
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
The temperature is a good 4°C to 5°C cooler in the upstairs rooms than on the ground floor level
this could be a thermostat location check the temp where the stat is and find a place where it is an average temp and then relocate
Jan 04, 2010 | Ruud Central System Air Conditioner
The picture is too big for the screen.
here you go heres the manual for you
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/KDL40V2500.pdf
Jan 31, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Central Air Conditioning
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
TV no pictuew
I have a sony trinitron kv35s40 and the problem is picture cuts off after a minute or so. We moved it to another room (it's really heavy 36") and it started with the problem.We live upstairs and can't bring it to a repair shop without a lot of effort.Please help What can it be?
May 26, 2008 | Sony KV-27S20 27" TV
Can see my network but wont connect
Yes you may trying chaing the channel to 11, because i have hear that chaning the channel will resolve this problem
Oct 23, 2007 | Belkin (F5D9230-4) Wireless Router...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
