Question about Mitsubishi Audio Players & Recorders
How do I hook upnakamichu home theatre system to a Mitsubishi 65 inch TV
  • 93 Answers
SOURCE: home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Posted on Oct 04, 2007
  • 7 Answers
SOURCE: Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Posted on Jan 27, 2008
SOURCE: Hooking Up a Curuts DVD6040 System
http://www.curtisint.com/web/browser.asp?productID=DVD6041
Posted on Feb 12, 2008
SOURCE: Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Posted on Jul 09, 2008
dunnbiker
  • 8546 Answers
SOURCE: i can not find the audio out jack on my 47 inch
You might name the model of the TV.
If the TV is a monitor it doesn't have any audio capabilites. What you should do, and owners of monitors must do, is get the best digital or analog audio from the same source the TV would get it - cable/sat/dvd/bd/game.
There is nothing to be gained by washing hi-fi multi-channel audio through a TV's sub-par audio electronics and turning it into grainy analog audio for consumption by higher-fi audio-specific equipment..
Posted on May 30, 2010
I'm trying to hook up extra house speakers to my vizio flat screen TV how do I do that
Hook your TV to a home theatre system. TV.s don't have enough wattage to handle several speakers.
Mar 16, 2015 | Vizio Televison & Video
I have a Dynex Flat Pannel TV with a DVD player in the TV. I have it hooked up to my HD line coming into the house. My question is: Is there a way to hook speparate speakers from the TV and by-pas the...
Yes you can provided your tv-has a headphone jack. Just plug in any regular computer speakers or the like into the headphones jack and the audio output would be switched to external speakers automatically. On the contrary if your tv does not have a headphone jack then you will need to obtain a home-theatre system and connect the stereo audio out ports to the audio in of the home theatre system. They have become very affordable these days and I have seen a Philips home theatre system(2.1) starting at around 120$.
Apr 04, 2011 | Dynex Televison & Video
How do you get sound to come from tv out of speakers of home theatre system
It just depends on the tv you have. If you hook up the RCA jacks to the (Audio out) of the TV into one of the (AUX in) ports of the home Theatre system you should be able to geet the sound that comes from the TV to play out the theatre system. If you are watching through a cable box you will need to hook the RCA cables to the cable box (Audio out) too the theatre systems (AUX in), in insted.
Mar 05, 2011 | Televison & Video
How do I get audio from tv through the home theater system? I have a mitsubishi wd65734 tv and a sony home theater syset.
plug your cable box and dvd/blue ray to the home theatre(audio AND video) , and then plug the home theatre's video output to the tv.
Nov 25, 2010 | Mitsubishi Audio Players & Recorders
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
I'm trying to get the xbox working through the home theatre system but I'm still getting the sound from the TV which has intergrated freeview. The Xbox is connected to the TV using an HDMI cable, the home...
you need to hook up the xbox' audio cables to the home theatre systems AUX in port and then have your system set on AUX, and you can leave your xbox' hdmi plugged into the tv, just be sure your on the correct AV chanel.
Dec 24, 2008 | Panasonic Home Theater System System
Dec 17, 2007 | Audio Players & Recorders
51 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
