Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
I have a WD62725 with blinking green light - Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
  • stanleyconce Jul 20, 2009
    Do you have a part #
    need more help
  • 3,037 Answers
This is a a very frequent problem that occurs in Mitsubishi rear-projection widescreen HDTV's, referred to as "The Blinking Green light of Death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other.
To fix this problem, you basically have replace the four (apparently inadequate) 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors). These capacitors are apparently undersized, in that they will eventually fail (usually after about 3 years) if and inevitably when there are voltage fluctuations in the circuit above 16 volts. (If you Google: "Mitsubishi + Blinking Green Light of Death", it's amazing how many other Mitsubishi rear-projection TV owners have experienced this problem.) It is recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur. If you have no expertise in electronic work, then find someone that does, hopefully a friend and this will be a cheap fix for you (under $10 for the parts). Make sure everything taken off is put back on, many times people forget to reinstall the back cover plate for the DM module, which has critical grounding straps essential to the proper functioning of the DM module. After all of this, the tv should work. Let me know how it turns out.
Benjamin
Posted on Jul 20, 2009
  • Benjamin Patri
    Benjamin Patri Jul 20, 2009
    I don't have a part number on hand. Just go into Radio Shack, tell them 1000uF/25 volt or 1000uF/35 volt capacitors and they will know exactly what you are looking for.
Mitsubishi WD62725 TV doesn't come on
Check and recheck that all connections are secure. Look on the circuit boards to see if anything looks wet. That would be fluid leaking from one of the tubes. One of the parts you put in may have issues. Check your voltages.
Jan 28, 2015 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi DLP WD62725 TV after powering down the timer light say blinking till unplug it then reset it to turn back on can any one help me
Good Day,
More than likey you have bad caps on DM Board.
It willcost about $450 to repair or you can do it yourself,.
On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V,
The DM PCB is on the left hand side of the TV when you take off the back cover.
Good Luck, BIG IRISH,.
Dec 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced the lamp in a wd62725. Green lights blinks fast but never cuts off.
need to have chassis completely rebuilt, specially p/s and fmt board. expect to pay around $500
Dec 10, 2009 | Televison & Video
I ordered the three repair kits for the WD62725 TV. I was having a "34" code and the local service provider said I needed a Format, signal, and power board. I replaced all of the caps provided in the kits....
Most likely a wire plug connection between the boards or where you unplugged one, as the code 12 means there isnt any errors with the set, so its almost certainly a wire connection double check the ribbon cables extra good.
Jun 21, 2009 | Televison & Video
Blinking Timer light on Mitsubishi WD62725
get a ohm meter and check all fuses ,and diodes they should all read 0. the ones do read something are bad replace them that means solder them out and back in
Mar 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Timer light blinking
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Nov 11, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
110 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
