Question about Cell Phones
I can't get the text to type in text box and the full ribbon will not show
My nakajima Ae-170 is not showing full ink on letters i type in
Wind the ribbon up exposed ribbon not used for while wil have voids in the characters.
Feb 07, 2017 | Nakajima Office Equipment & Supplies
How do I create mirror image letters?
I will assume you need to print part of page backwards or upside down.
This is pretty easy using a Text Box. A text box can have a border, be opaque or transparent, force the text to flow around it or not.
To create a text box, go to the Insert tab, click Text Box and then I like to choose "Draw Text Box." You can draw it in the general area you need it. It's ok to use one of the preset Text Boxes, too.
Type your text inside.
To flip the text around, double-click your text box to activate it, and then look for the Rotate button in the "Arrange" section on the Ribbon. You can flip it horizontally or vertically as many times as you need to make your text upside-down or a mirror image.
Then edit your box - border, color, text wrapping, position, etc.
Sep 19, 2014 | Microsoft Office Word 2007 Full Version...
How do I delete text messages when it reads full
Ok,so what you should do,is delete some of your threads, and go onto settings and onto SMS counter and up it to 10,000 if your using a smartphone, hope this helped :)
Aug 15, 2014 | Cell Phones
Hi, I have an IBM Wheelwriter 30 Series II. When I type text it does not type the bottom 20 % of letters. I changed the ribbon and made sure that the roller was securely locked down. Any suggestions? ...
yes in the carrier ribbon there is a adjustment of ribbon to fix it up and down.
take out the ribbon.
see the cam from where the ribbon carrige lift up.
in side that cam a adjustable screw from that screw you can adjust the ribbon hight.
Nov 25, 2010 | IBM Wheelwriter 30 Typewriter
No text show up when typing
Do you hear the type hitting the paper? Is the ribbon installed properly and in good working order (a carbon film ribbon is all black, or a cloth one has ink in it)?
Jul 10, 2010 | Brother ML-100 Typewriter
In newspaper quark format use in typing. i am new commer. i learnthis software to do work. so please detail me quark
In order to type in Quark you need to first draw a text box. The symbol in the tools pallet is a box with an A inside. After you draw the box you can assign what type style and size to use with the pallet at the bottom of the screen. This is true for each new place you want to add text.
Nov 21, 2009 | QuarkXPress 7 Full Single User Mac/Win...
How do you type inside a microsoft powerpoint slide?
default.aspx?assetid=za790050001033Show All default.aspx?assetid=za790050011033Hide AllDo one of the following:
default.aspx?assetid=za790050011033Add body or title text
Note If your text exceeds the size of the placeholder, Microsoft PowerPoint reduces the font size and line spacing incrementally as you type, to make the text fit.
default.aspx?assetid=za790050011033Add text to an AutoShape
Note To add text to a line, connector, or freeform (freeform: Any shape you draw by using the Curve, Freeform, and Scribble tools. Freeform shapes can include straight lines and freehand curves. They can be drawn opened or closed and can be edited.) AutoShape, you must add text using a text box.
default.aspx?assetid=za790050011033Add text to a text box
  1. On the Drawing toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Text Box default.aspx?assetid=za060447551033.
  2. Do one of the following: default.aspx?assetid=za790050011033Add text that stays on a single line
    default.aspx?assetid=za790050011033Add text that wraps
    I hope this helps
Oct 27, 2009 | Microsoft Windows Vista Home Premium with...
Can I print in color with a Zebra 105se
Thermal printers don't have any 'color' of their own; the 'printed' text/numbers are actually only areas subjected to heat from the printhead which exposes the color of tiny beads of ink that are on the paper itself by melting them. Use a fingernail to 'score' the paper and you will see it change color just as happens in the printer.
Oct 14, 2009 | Zebra 105Se Thermal Printer
I can't see my text - nothing new, no new software, white background, black text, font size is big enough, but I still can't see it...HELP!!!
Make sure you black is in the lower palette box as shown. When it's reversed with white below the black, as you type the text will show in black, but not within the actual text are. Take a look at this image to see what i'm talking about.
Sep 16, 2009 | Corel Paint Shop Pro Photo X2 Ultimate...
My type tools does not work.
Perhaps you've got the text color set to the same color as your background (both white). With the text tool selected, left-click on your document once, then left-click on the 'set the text color' box in your toolbar. Choose a color that is dark enough to show up in your screen. Make sure your text size is large enough to show at your current screen resolution.
May 29, 2008 | Adobe Photoshop CS2 for PC
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
