Question about Garden
Do I mix the fuel for my shindiawa 575 chainsaw
  • Garden Master
  • 15,716 Answers
Re-fill with fresh fuel of the correct mixture
(Shindaiwa Premium 2-cycle Engine Oil
and gasoline-40 : 1 ratio;
other brands-25 : 1 ratio).
Workshop manual
http://www.golftechs.us/Manuals/shin%20chainsaw_current.pdf
Posted on Dec 12, 2016
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: what is fuel oil mix for the 136
Page 8 of your manual says 40:1 (3.2oz/1gal) Stihl or Husqvarna 2 cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Posted on Oct 30, 2009
  • 320 Answers
SOURCE: factory carb settings for dolmar ps460 chainsaw
Try squirting a little starting fluid into the carb and try to start. If it will try to run, you have a fuel problem. Try changing the fuel filter first.
Posted on Apr 07, 2012
  • 3 Answers
SOURCE: little ****** chainsaw fuel mix
32:1 is the best mixture to use. 50:1 is what's recommended by most manufacturers for home owners grade small 2 stroke engines but 32:1 with a quality oil and premium fuel with fuel stabilizer will more than likely double the life expectancy of your power equipmen.
Posted on Apr 17, 2014
AndrexT
  • 15716 Answers
SOURCE: How to mix fuel and oil
Page 14 here
http://www.manualslib.com/manual/453515/Homelite-Ranger-Ut10926.html?page=14#manual
Posted on May 27, 2016
I no this is probably the dumbest question youve heard bit dp I mix the gas for my shindiawa 575
if it is a 2 stroke --yes you mix the 2 stroke oil and fuel in a can before filling the tank
if it is a 4 stroke then no --the oil goes in the sump
now for my d**b questions --do you know what motor you have and why are you not reading the the user manual first?
Dec 12, 2016 | Garden
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
***** 575 wont run when saw is turned sideways
check fuel hose and fuel filter position in fuel tank, if filter is stuck at top of tank saw will run out of fuel, also is hose has a crack or break it will not run properly.
Oct 01, 2014 | Husqvarna 575 Xp Chainsaw Engine Cylinder...
What is the gas/2 cycle oil mixtuure for a husqvarna 55 chainsaw
These saws were normally ran on a slightly richer mix. The reason was becuase of the mix oil available. I would recommend running a 40:1 or 50:1 mix. Make sure you use an "FD" rated mix oil and Premium ethanol free fuel.
The premixed fuels / oils are even better. They contain the FD rated oil 95 octane fuel and no ethanol.
Jul 20, 2014 | Husqvarna Chain Saw Models 51, 55
I used fuel from old chainsaws sitting in garage and used it on my Echo CS-330T. I barley got it and it was basically new with a few hours of use. I guess the fuel was old and the gas was probably not...
Use echo 2 stroke oil Do not use ethanol fuel, use a premium fuel and mix with the oil. Empty all the old fuel out of the saw, Fill with fresh fuel. Should solve the problem
Oct 05, 2013 | Garden
What is the fuel/oil mix for a mcculloch 14inch chainsaw 2.0 cib?
If you use newer synthetic oil it covers a broad range of fuel/oil ratios with one mix. it will allow you to use one fuel mix for all your 2cycle equipment
Aug 22, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mixture for a mcculloch 610 chainsaw
40:1 is the manufactures recommendation as seen here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/62391767564ad36188256c2f001cbcd4?OpenDocument
I quart of premium fuel (32 ounces) to 3/4 ounces = 42.7:1
No chainsaw or any other 2 cycle device has EVER recommended 42.7 to 1.
I gallon of premium fuel (128 ounces) to 3.2 ounces is 40:1.
Any chainsaw outlet sells 2.6 ounce containers of 2-cycle oil that should be mixed with 1 gallon of premium fuel. That is 50:1 and may be safely used in all 2-cycle engines once adjusted to operate with this mix. Any mix over 1.5 months old should be consumed in a 4 cycle engine. HTH
Lou
Feb 04, 2010 | Garden
What is the correct fuel to use
Lou
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
