Question about Stihl Garden
I have an stihl 029 super chain saw that the spark plug won't stay in it. What parts do I need to fix it?
  • Stihl Master
  • 20,508 Answers
If the threads are crossed, stripped or loose, you need to take it to an engineering place and have a 'helicoil insert' fitted, this is a new steel insert that is tapped and threaded into the head after the hole has been enlarged a little.
helicoil insert Google Search
Posted on Dec 12, 2016
Engin parts for 029 super stihl chain saw
perhaps a STIHL dealer can assist you .
Dec 09, 2016 | Cars & Trucks
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
I can't tighten the chain on my stihl ms 251 chain saw
Pull the side cover and check for a broken or misaligned chain tensioner. I assume that you have loosened the bar nut on the side cover before attempting to adjust the chain tension. The methiod varies depending on whether your model has the side chain tensioner or the quick chain tensioner.
Dec 08, 2013 | Stihl 029 039 Ms 290 310 390 Chain...
Stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Replacing the fuel vent hose on a Stihl chain saw
If it's the clear vent hose that connects to the tank on the left side, that's it. There is a brass plug inside the hose that meters outside air in the tank to regulate the pressure. The hose connects to the tank nipple, done.
Nov 19, 2009 | Garden
Garden Logo
46 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
