Question about Dakota Watches
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
  • Dakota Master
  • 16,083 Answers
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Posted on Dec 12, 2016
    The pendulum on my grandfather clock no longer works .. It is not a problem with batteries . It just no longer moves .
    wind the spring up
    if is battery operated replace the battery that swings the pendulum
    Aug 30, 2017 | The Watches
    I purchased a Howard Miller grandfather clock and the clock is keeping time but pendulum is barely moving. What's the problem?
    Hi Pam,
    I have a Howard Miller Grandfather clock and the pendulum swings very slowly and from far left to far right travels only about three inches at best. It doesn't need to move any more than that to make the "Verge" move the "Escape Wheel" to rotate the gears to keep the hands moving at the correct tick.
    Howard Miller Grandfather Clock
    Dec 06, 2016 | The Watches
    How do I set the Chimes on the Ergo Westminster Clock
    The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
    Apr 02, 2012 | Watches
    Coaster model 900723 grandfather clock doesn't keep time
    Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
    Nov 20, 2010 | Watches
    We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
    Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
    Nov 19, 2010 | Watches
    My new wall clock chimes 2 minutes BEFORE the
    You will need to do a mechanical adjustment to the hand.
    Loosen the hand nut and adjust the hand the tighten.
    Hope this tip helps to solve your problems
    R/
    David
    Mar 19, 2010 | Watches
    I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
    Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
    Feb 02, 2010 | Watches
    The pendulum stopped swinging...the clock and chimes work well
    Hi
    This clock short of needing a full service may simply be out of beat.
    Taken from my web page located at:
    http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
    "HOW TO PUT YOUR CLOCK IN BEAT"
    -Included below is a 10-second sound <snip> of a clock both in and out of beat.
    IN BEAT ////////\\\\ OUT OF BEAT
    · Turn on your sound and click on the clocks above for a sound clip.
    -One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
    -I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
    -As I'm sure we now realize a clock must be in beat but not always level to function properly.
    · Above is the verge with a slip clutch.
    · Often found on Grandfather clocks and requires only a long swing to get it in beat.
    -To get the clock on the right side in beat you would need to push the verge assembly to the left.
    -If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
    R/ David
    Nov 08, 2009 | Seiko Chiming Pendulum Tambour Mantel...
    Elgin grandfather clock chimes not working
    I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
    If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
    Mar 29, 2009 | Elgin 0518709FA
    Watches Logo
    100 people viewed this question
    Top Dakota Watches Experts
    J.D. Browning
    J.D. Browning
    Andrew Taylor
    Andrew Taylor
    Are you a Dakota Watch Expert? Answer questions, earn points and help others
