60"walnut media fireplace my fireplace light has quite working. what should I do
Everything else works on the fireplace. except for the remote and light
poolseman
  • 206 Answers
SOURCE: Shutter Only Fires at 60
Remove transport/winding lever and loosen the retaining ring underneeth. Gently lift shutter speed dial and reseat it. Tighten the retaining ring and reattach winding lever. ( the shutter speed dial is not engaging the mechanism inside the camera and you need to establish proper connection ).
Posted on Aug 28, 2007
  • 21 Answers
SOURCE: parking lights quit working 2002 dodge ram 1500
does the instrument panel lights come on when you turn on the park lights only (no headlights)? If not it could be the switch itself.
Posted on Jun 17, 2009
projdoc
  • 2237 Answers
SOURCE: This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Posted on Aug 26, 2009
  • 744 Answers
SOURCE: Charmglow electric fireplace bad remote control
Here is the home site for Charmglow - you could try to call them and see what they say. I would hope they want to keep their customers:
Charmglow Products 3701 Charlotte St, Pittsburgh, PA 15201-3201 (412) 683-6434 .aBtnGetDir { display:inline-block; width:107px; height:22px; text-decoration:none; vertical-align:bottom; cursor:pointer; } .aBtnGetDirLeft { float:left; height:22px; width:92px; overflow:hidden; font-size:0.85em; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -99px -401px; color:white; font-weight:bold; text-align:right; vertical-align:middle; line-height:22px; } .aBtnGetDirRight { float:left; height:22px; width:15px; overflow:hidden; background:transparent url('http://sp.ask.com/sh/i/a11/shared_sprite_06.png') no-repeat -301px -401px; }
Posted on Dec 12, 2009
  • 4736 Answers
SOURCE: I have a Skytech 1001
Rhonda, if you have the On/Off/Flame Height Remote Control ... from what you have described (it's working in reverse) someone has wired it backwards to the control valve. With this particular remote, there is a positive and a negative. Reverse the wires that are connected to the gas control valve (at the control valve. Not on the Black Remote Box) and everything should be fine. If you need more help contact Skytech Technical Service @ 888-672-8929 Monday - Friday. They are great people to work with.
Posted on Jan 15, 2011
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
Light for flame went out. How do I replace it?
Remove the firebox glass (actually it's plexiglass) and set off to the side out of the way. Now, Remove the logs from simulated burner and set off to the side out of the way. The glowing coal effect plastic panel under where the logs were, should lift out, exposing the 60 watt, small base, chandelier bulbs, They unscrew counterclockwise from their individual holders. Replace the bulbs and reinstall everything else in reverse order, from the way you took it out. Caution: Be sure the Master On/Off Switch for the fireplace is in the OFF position, before starting any work on the fireplace.
Hope this helps you to solve the problem.
Apr 15, 2011 | Leisure HOMEPRIDE Electric Fireplace...
Remote works for everything except off/on
Ur tv remote have a dead CPU or the rubber plastic black knobs traces on the PCB board is worn out.Try website like Remotes.com to buy an exact remote to ur original remote.
Nov 24, 2010 | Mitsubishi VS-60111 60" Rear Projection...
I have a liftmaster 1255km(model) with a clicker remote opener model KlIk2. All devices that were used to open the garage lost the ability to open. I have reprogrammed all devices including hand held...
I think you are saying everything except the Klik2 has quit working. If that is so check to see if the light in the wall button is blinking. Press the 'lock' button for 3 seconds and the light should glow steadily and the remotes will work. If you are saying all remotes plus the Klik2 has quit then your logic board has failed.
Sep 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Electric fireplace still works, except the flame does not light up anymore? Is there a way to fix this? It is a Chauffe-Air, Model# 6901740100 Cat.No. DFB4047 Mod. Level: MOD A Serial # 26806D6F 093. I...
Find an access door on the back or side or both.
check lightbulbs.
Do not replace with anything but exact bulb.
try taking the bulb to Lowes...I've gotten luck there before with odd bulbs...they have a special drawer for them.
Good luck,
Vinnie
Mar 21, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Dec 12, 2009 | Kitchen Appliances - Others
Flickering lights have stopped working
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
Jun 18, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
