Question about Cell Phones
How do I set quiet mode? - Cell Phones
  • Cell Phones Master
  • 3,648 Answers
Usually
settings
sound
sound mode
a model number would allow us to answer this question on a more specific way
Posted on Dec 12, 2016
How do I disable the sound on my canon mx870 printer? It makes loud tones at start-up and at shut-down. My roommate is VERY bothered by it and I wouldn't mind the printer not announcing that I have turned...
I was having the same problem. This is how to fix it. Go to the actual printer, press the setup button, scroll and click on device settings, scroll down and select device user settings, select volume settings, then you can turn off all of the sounds of the printer. I also put it on quiet mode just in case. Hope that helps!
Mar 11, 2011 | Canon PIXMA MX870 Wireless Office...
My Blackberry curve 8330 goes to the quiet mode even though my profile is set for normal ring. Only thing I can do to fix it is turn off and remove battery
maybe see your advance option on the top right corner.
mine goes to quiet mode and i identify which call and/or msg i wanted to receive normally.
good luck
Aug 13, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Generac gardian model:005885-0 running rough
Check the spark plugs, ignition coil etc and try to start it manually.
Jun 15, 2010 | Generac Guardian Quietsource 25,000 Watt...
HP Deskjet 6988 Printer Installed properly. Can be detected by the network (both wired and wireless) BUT WON'T PRINT BECAUSE QUIET MODE IS ALWAYS ON. Puts documents to queue but will not print. Tried all...
Hp printer properties best to do this with the usb attached. in the properties you will find printer name make model and setting go to settings and a list with links on depending on what windows you are using, there is auto shut down (2hr) etc on one of the drop lincs is standard and quiet mode. click to standers and save it should be out of that setting now. if still stuck use this link to fix problem with the printer. HP DeskJet 6520 6620 6840 6940 and 6980 Printers Top Cover Open Message...
Jun 26, 2017 | HP Deskjet 6980 InkJet Photo Printer
Sony dvp ns67p plays dvd's at a quiet
I changed the audio settings to TV MODE.
and now the volume is perfect
Oct 05, 2009 | Sony Televison & Video
My printer wont load paper so i can print
Hiya
My Canon started doing the exact same thing. I tried several mods but no luck. Seemed like it would **** hard when starting to print thus mis-aligning the paper. What I found that did worked and solved my problem was putting the printer into 'quiet' mode. In this mode it doesn't **** the paper in as fast and thus doesn't jam. I don't think it has jammed since the change and there's no really noticeable slow down in the output.
Pull up the properties dialog for the printer and go to the maintenance tab.Select 'quiet mode' button and then set it to always use quiet mode. Worked for me. Hope it works for you!
Jan 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Sound Quiet Mode
try to reset settings as described in user manual below:
http://www.techteam.gr/mobile/specs/guides/SamsungSGH-E370.pdf
Reset settings (Menu 9.10)
Use this menu to reset the phone settings, display
settings, and sound settings individually.
1. Press [ ] to select the setting categories to be
reset
2. Press <Reset>.
3. Press <Yes> to confirm the reset.
4. Enter the phone password and press <OK>.
The password is preset to 00000000. You can
change this password
Jan 20, 2008 | Samsung SGH-E370 Cellular Phone
Samsung SGH E-350
There is # button which also indicated a sign with "vibrator phone". Just long press it and it will release quiet mode. Again pressing this button in same maner will again put your phone in quiet mode.
Jan 10, 2008 | Samsung X640 Pink Color Cellular Mobile...
Quiet Mode
Press and hold down the # key for about 2 seconds, this is how you switch between Quiet mode and normal mode Regards
Jul 30, 2007 | Samsung SGH-D600 Cellular Phone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
