Question about Sewing Machines
Winding the bobbin is not working. When I am winding the bobbin, the bobbin is not turning while winding so it is not getting fed.
    Top Expert:
  • Sewing Machines Master
  • 8,189 Answers
Try this link and scroll down the page there are people on there say what might be the problem hope this helps you out... https://answers.yahoo.com/question/index?qid=20100416173210AAgO4ZZ
Posted on Dec 12, 2016
Re Janome 7330 bobbin winding problem. Thread jumps out of the top guide when bobbin is winding. I've tried everything; different speeds, main spool upright,tightening the screw on the thread guide.
Take a look at this video. There are others too. That is a really unusual way and nothing like the Singers, and Pinnocks that I have used. If you want to see other videos, there are a few. Google 'Janome 7330 bobbin winding', and then click on the Video tab. Let me know how you get on?
How to Wind Bobbin on Janome
Dec 04, 2015 | Janome Sewing Machines
Tangled thread after winding new bobbin
Try winding it the opposite way you are doing it now in regards speed. If you are winding it on full speed, try winding the bobbin slower. If you are winding it slow, try faster. Also check that the thread is threading properly and is not catching somewhere, and also that the tension is correct. Finally, test with a thread that you have not experienced problems before.
Jun 30, 2015 | Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
I am having problems winding the bobbin as it will not stop when full and it is very uneven. I have just had it serviced. Ann
Double check you are threading correctly for bobbin winding. It should wind neatly till it can't turn, and then you stop winding; at least this is how it works on the 8000. Perhaps there is some thread blocking the thread guide for the bobbin winding
Oct 09, 2010 | Janome Memory Craft 9000 Computerized...
My bobbin isnt winding correctly
re-thread sewing machine for bobbin winding. There should be a screw looking thing that holds the thread taut while threading
May 26, 2010 | Euro-Pro Shark 60 - 384
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
Bobbin Winding message appears when machine is turned on
Is the bobbin winder holder clicked over to the right like you are trying to wind a bobbin? If so, and you are not trying to wind a new bobbin, click it over to the left.
Mar 09, 2009 | Kenmore 19233 Computerized Sewing Machine
Winding the Bobbin
I have the same problem and was skeptical of the drop of oil solution but it worked. I had taken my baby lock ellure apart while investigating previously and found nothing else wrong. Tried a few drops of oil and after a moment it started winding noisily and then settled right in!! Working perfectly now!
Jan 20, 2008 | Baby Lock Ellure
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
