Question about LG 32LG30 32 in. LCD HDTV
Hi, We have 2 LG TVs, for some reason we can't find the manuals.We have tried everything on the handset to switch to digital, what are we doing wrong. The set up on both TVs looks the same. We would appreciate any advice. Kind Regards, John Preston.
  • 188 Answers
This set does not have DTV ,i found a spanish manual and i saw that there is no DTV input,only HDMI input.
Posted on Jul 21, 2009
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
Id like to unlock my lgks360 for free but im finding it hard. could you give me a code to do this please?
Only trust best unlocking specialist for unlocking your mobile , it will be the best & safest way for unlocking . In order to unlock your Lg KS360 MOBILE make use of this site wickedunlock ,select the network you need , then get the unlock code here , using unlock code specified in it proceed unlocking your mobile & gain solution .
May 28, 2011 | LG Cell Phones
I NEED THE 16 DIGIT CODE TO UNLOCK MY LG CU920
How to enter Unlocking Codes for LG Phones for Various U.S
Below are instructions that work for most network providers.
How to Unlock LG (most models):
1:Insert not-allowed SIM card
2:Power on the handset- phone will display “phone restricted”
3:Select “Cancel” - phone will display “phone restriction code”
4:Enter the SIM unlock code
5:Select “OK” - the handset is now successfully unlocked
How to Unlock LG KG245 (Vodafone Australia)
1:Insert a Vodafone Australia working SIM card.
2:Ensure the phone is charged and then switch the phone on.
3:Optional Step: If the SIM card has a PIN, enter your PIN number
4:Wait for the phone to power up then enter 2945#*7101#
5:Select Menu , then go to Settings > Security > SIM Lock > Network
6:Select Deactivate and enter the 8-digit unlocking code provide for your handset.
7:The handset will be unlocked automatically and will display “Done”. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
How to Unlock LG KG800 or TG800 Chocolate:
1:With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2:Go to: Settings>Security>SimLock>Network
3:Select deactivate. Enter the unlock code,
How to Unlock LG C2000:
1:Power on the handset - phone will display “phone restricted”
2:Select “Cancel” - phone will display “phone restriction code”
3:Enter the SIM Unlock code
4:Select “OK” - the handset is now successfully unlocked
1:With allowed sim card in the start menu type: 2945#*3311#.
2:Handset shows saved, then return to startup screen
3:Press Menu key, choose Settings > Security > Sim Lock> Network eactivate, handset will now show ‘Enter NCK’
4:Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1:Switch ON your phone with a not allowed SIM card.
2:Compose: 277634#*#.
3:Go to menu “SIM Lock”.
4:Enter the unlock code, which you can buy any online store .
1:With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2:Select ‘Sim Unlock’ menu #
3:Enter NCK code then validate
1:With a not allowed sim card enter Pin code then validate, type: 277634#*#
2:Shows test menu
3:Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4:Handset shows ‘Enter NCK’
5:Enter code, then hit OK.
1:To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2:Enter the code
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1:Insert non-Cingular SIM card.
2:Power on the handset. Phone will display “Invalid SmartChip”
3IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4:In Idle screen, enter 159753#*#. Phone will display “Enter NCK, Remaining 5
5:Enter the 8 digit SIM unlock code, which you can buy any Oline phones.
6:Select “OK”. The handset is now successfully unlocked
How to Enter Unlock Codes on all other LG cell phones:
Switch ON your phone with an allowed SIM card
Then compose:
2945#*5101# - (if you have a LG 510w)
1945#*5101# - (if you have a LG 1200 & B1200)
2945#*5221# - (if you have a LG 5200 & 52200)
2945#*5301# - (if you have a LG 5300)
2945#*5401# - (if you have a LG 5400)
2945#*70001# - (if you have a LG 7020)
2945#*7101# - (if you have a LG 7100)
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
2945#*70001# - (if you have a LG7250T)
2945#*2201# - (if you have a LG C2200)
2945#*5301# - (if you have a LG T5100)
2945#*3311# - (if you have a LG C3310)
Go to “Menu” and then to “Settings”
Then select “Security”
To finish select “Network Provider” and select “Deactivate”
Enter the unlock code, which you can buy Online store unlock-cell-phones.
How to Enter Unlock Codes on all other LG U400 Shine (2 codes needed):
1:Insert the network SIM in the handset which works with the phone (from the locked carrier).
2:Enter 2945#*88110#.
3:The phone will then prompt ‘Unlock sim’. Press OK.
4:The phone will then prompt ‘Network Unlock’. Press OK.
5:The phone will then prompt- ‘Input Network Control Key’. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it.
6:It should give you the message: Success.
7:Come back to the main screen and Enter 2945#*88110#.
8:The phone will then prompt unlock sim. Press OK.
9:The phone will then prompt Network Unlock/ Lock but if you scroll down
10 :you will see a message Enter SP Lock. Enter SP Code.
Then press OK.
How to Enter Unlock Codes on all other LG KE970 Shine:
1:Switch ON your phone with an allowed SIM card
2:Then compose: 2945#*9701#
3:Press CALL.
4:It should you ask you for the code.
How to Enter Unlock Codes on all other LG TU720 Shine:
1:Put in a non-allowed SIM, phone says invalid SIM card
2:Now enter *#865625# then enter your 16 digits code.
How to Unlock LG KG800 Chocolate Without a Code (not reliable):
1:Insert SIM from the network that it is locked to.
2:Turn on phone.
3:On home Screen, slide up phone.
4:Type 2945#*#
5:ENG. Mode menu should appear.
6:Go Down to Factory Reset. Select it. May take a few minutes to reset!
7:This will reset the phone back to before the phone was locked to a network.
8:The phone will automatically restart (the network logo at start up will not change).
9:Now insert any SIM card and the phone should turn on normally
10:The phone is now unlocked and you can customize the setting as you like
How to Unlock LG Vu CU920
June 11th, 2008 by Eric
On the AT&T Network, to unlock the LG Vu or CU920, it’s pretty simple:
Enter *#865625# then the 16 digit unlock code*
*The 16 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
Dec 05, 2009 | LG Vu CU920 Cellular Phone
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Nov 10, 2009 | Panasonic Lands Phones
My lg kg 300 is dead not runing or not lifes again
Remove the battery immediately. Don't put back the battery again at all in your handset until and unless your handset get fully dried. Also do not try to Switch On your handset, as this will result in permanent damage of your handset's main board.
Take your handset to the Authorised LG Service Centre and they will do the needful. Don't try to open it yourself.
Apr 23, 2009 | LG KG300 Cellular Phone
Unlock LG Chocolate
PHONE UNLOCK PROCEDURE
Please follow the instructions below to unlock your LG KG800 handset:
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Enter 2945#*7101# while in standby mode
4. Select Menu, then go to Settings > Security > SIM Lock > Network
5. Select Deactivate and enter the 8-digit NCK unlocking code provide for your handset..
6. The handset will be unlocked automatically and will display "Done".
Mar 02, 2008 | LG KG800 Cellular Phone
LG KG800
Feb 24, 2008 | LG KG800 Cellular Phone
Lg chocolate phone
In which country did you buy it? For Australia try the following.
Feb 22, 2008 | LG KG800 Cellular Phone
LG 32LG30 32 in. LCD HDTV Logo
103 people viewed this question
Computer Repairing
Computer Repairing
