Question about Radio Communications
Date of browning 40 cal. 2w5nt52593 - Radio Communications
    Top Expert:
  • 8,248 Answers
Win 1894, s/n 857903, in 32-40. How common is this?
in 32-40 fairly unusual it would appear. Lots of information for you here.
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... totally accurate database of serial numbers from 1866 forward that we are aware of.
[PDF]Winchester Firearms Manufacturing Dates by Serial Number
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
totally accurate database of serial numbers from 1866 forward that we are aware of. ... 94 -. 95 -. 96 -. 97 -. 98 -. 99 -. MODEL 1866. 2. 12476 TO 14813. 15578 .... 32-. 1087836. 62-. 2551921. 03·. 291506. 33 -. 1089270. 63 -. 2586000. 04 - ... 40 -. 1142423. 70-. 3381299. 11-. 599263. 41 -. 1191307. 71-. 3557385. 12 -.
Winchester Model 94 - Gun Collections Online
guncollectionsonline.com/winchestermodel94.htm
  1. Cached
  2. Similar
Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .38-40 Winchester, and .44-40 Winchester, .410 shotgun, 30-30 caliber (30 WCF), ... began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 30 30 ? ccookin is offline ... Winchester 94 32-40 21 posts 13 Mar 2013 Original winchester model 1892?? 10 posts 19 Jul 2010 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Winchester 1894 date of manufacture. - Shooters Forum
https://www.shootersforum.com/winchester-94.../66444-winchester-1894-date-manuf...
  1. Cached
  2. Similar
Jun 22, 2010 - 5 posts It seems that date of manufacture numbers are probably off as much as two years in this time frame. .... Winchester's production of the Model 94 averaged about 35,000 units per .... 32-40 Rifle - serial number 692, 12-14-1894
Blue Book of Gun Values - WINCHESTER RIFLES: LEVER ACTIONS ...
bluebookofgunvalues.com > Gun Values > WINCHESTER
  1. Cached
  2. Similar
WINCHESTER RIFLES: LEVER ACTIONS - 1860-1964 gun model and pricing information. ... lever latch, adj. sporting type rear leaf sight, serial numbers are in three digits only. ... .32-20 WCF, .38-40 WCF, or .44-40 WCF cal., iron frame with sideplates, .... 1940-1964 mfg. without saddle ring, barrel is marked Model 94.
Model 1894 ' Winchester Collector
winchestercollector.org/models/model-1894/
  1. Cached
  2. Similar
.32-40 - introduced in 1894 ... As serial numbers approached the one-million mark, the official model ... The Winchester Model 1894 Saddle Ring Carbine
Win 1894 857903 in 32 40 Google Search
Nov 15, 2016 | Computers & Internet
Where can I get a barrel for the above.Thanks,
It should look like a Browning, he designed it. It is the gun which started WWI, as well.
The Numrich Corp may be able to supply one, make an enquiry
http://www.gunpartscorp.com/Manufacturers/AutoPistols-35558/1922-34859.htm
Mar 26, 2016 | Optics
How do I rid my house of brown spiders?
If you mean the "brown recluse spider" you should cal terminators becauseit is rather dangerous
Read here
http://www.emedicinehealth.com/spider_bite_brown_recluse_spider_bite/article_em.htm#brown_recluse_spider_bite_overview
May 04, 2015 | Miscellaneous
How do you set the SWR on a cobra 29 LTD classic radio
the same way you set it on any other radio.Look at the face of the set,you will see a switch that says S/RF,CAL , SWR. Now look at your meter and you will see a triangle that shows cal.Put your set on ch 1 with the switch in the cal position and bring the needle to that calibrate line on the meter by keying the mic. now release the key and set switch to SWR and key the mic again.Now write this reading down.Repeat for channels 40 and 19. If the reading is higher on 40 than on 1 you need to shorten the ANTENNA.If its higher on 1 than 40 you need to make your ANTENNA longer Always check 19 to make sure you have an average SWR. Any reading under 1.9:1 is good
Jun 15, 2014 | Cobra 29 LTD CB Radio
How do u take apart a 40 cal pistol
first of all if you don't know how to take it apart ask some one that does. Go to a gun shop and ask. you should make sure you have a permit for it also.
Nov 15, 2012 | Radio Communications
Sharp spc403 instruction manual
hold "Cal C/F" for 2 or 3 second then the year will blinking. The press "Adj CH" to move year.
Then press "Cal C/F" again it will blink month then press "Adj CH" to change month, and date.
May 21, 2012 | Audio Players & Recorders
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
Color ink was out of ink
The ink may of expired becase it was not used by a sertan date or there could be dirt jaming the ink nosels.
May 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Radio Communications Logo
55 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
